Tim
Oct 18, 2011 11:50:23 GMT
Hi all
Does anyone know iof there any specific rules to be aware of regarding hazard warning lights at MOT time?
The Carlton has failed the MOT - kept blowing a fuse that site on the hazards/radio/clock/interior light circuit. MOT fail due to hazards.
We think its a borked switch - its lost a contact somehow (may have fused though it) and a replacement is unobtainable.
Does the Switch need an LED light for MOT time?
Looking at the switch, there are 5 connections in constant contact, and 3 activated upon the switch catching. If I permantly wire the 5, and add a push switch for the other 3, would this work, and would this fail the MOT because there is no ON light on the switch?
pulling hair out :-(
cheers
Tim
Oct 18, 2011 11:54:57 GMT
Oct 18, 2011 12:00:05 GMT
Tim
Oct 18, 2011 12:13:51 GMT
Thanks. Willl have a look tonight. I have a new cavalier switch but pin out pattern is different.
Got a week to sort it, running out of time!
Oct 18, 2011 19:44:02 GMT
I've never had my hazards checked at an mot :?
Tim
Oct 18, 2011 21:13:18 GMT
Link isn't working. Is that a Carlton hazard switch?
Oct 18, 2011 21:18:14 GMT
Works here!
Yeah, it's a carlton switch, which apparently is the same as a Lotus Elan switch. It's 31 euros on that site.
Oct 18, 2011 21:20:29 GMT
bl1300
Oct 18, 2011 21:22:05 GMT
I've never had my hazards checked at an mot :? How old is your car? Can't remember the exact years but certainlly early 70s car do not need them for the MOT. However if they are fitted they should be in working order.
Current fleet.
Tim
Oct 18, 2011 21:29:27 GMT
They want over 70 euros for postage :-(
Oct 19, 2011 10:19:36 GMT
Last Edit: Oct 19, 2011 10:20:23 GMT by damien4884
1977 datsun 810 180b estate
Colonelk
Club RR Member Number: 83
MOT Time - HazardsColonelk
@colonelk
Club Retro Rides Member 83
Oct 19, 2011 13:17:02 GMT
Was going to say what era of Carlton. Ive got a box of switches somewhere. If not a plea on TotalCarlton.com normally will get you bits and pieces
Tim
Oct 19, 2011 20:46:27 GMT
Plea on totalcarlton not successful.
It's a 92 L.
Tim
Oct 19, 2011 20:56:50 GMT
Damien - star!
I've never had my hazards checked at an mot :? How old is your car? Can't remember the exact years but certainlly early 70s car do not need them for the MOT. However if they are fitted they should be in working order. On any car. I've taken up to a '99/00 car through and never had them tested, in dozens of VOSA-run tests.
Tim
Oct 25, 2011 10:02:35 GMT
MOT place believe hazards are a fail - they spent a day trying to fix wiring, and failed, so didnt charge me - I don't think they are scouting for work. Auto electrician has found the short - in the roof lining between the front and rear courtesy lights Need to pay for a new MOT though as couldnt source parts/fix problem in the 10 working day window. Botheration! Bet they fail it on somethig else now.
murran
Oct 25, 2011 20:12:51 GMT
hazards and tell tail need to work ignition on and off......
Tim
Oct 27, 2011 13:00:42 GMT
Woo, back on the road, this time with no advisorys (had one for slight corrosion 2 weeks ago!)
