Hi guys,
Hope you are well.
Went to go out in the viva today and it wouldn't start. To cut a long story short checked the usual (fuel and spark) and had no luck, all was well.
Pulled off the breather pipe that goes from the rocker cover to the air filter housing and it ran.
Watching the outlet pipe on the rocker cover and there is quite a lot of combustion gas chugging out of it, leading me to the conclusion (correct me if i'm wrong) that it was choking the engine as it was turning over causing it not to start. We played about with it a few times (On - didn't start, Off - Started ok) and I'm pretty sure this is the case though. Also, there was a fair bit of oil in the air filter.
Anyway... I'm thinking it needs a top end rebuild now. Valve seats, guides and stem seals etc. Firstly, do you agree?
Secondly, is this the right Head gasket set for a 1256 HC on an L plate. www.ebay.co.uk/itm/PAYEN-HEAD-GASKET-SET-VAUXHALL-VIVA-CHEVETTE-CHEVANNE-/150603533324?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2310ab8c0c
Thirdly, anyone know where to get valve guides+stem seal for said machine.
Fourtly, if there is anything you can add to the above, please do. All comments greatly apreciated!
Pic of the steed for gratitude!
Hope you are well.
