will930
Decked K11 Micra - RetroRunner Mk2 Golf
Oct 11, 2011 21:05:43 GMT
so it comes to that time when blingy stuff happens and my brakes are due for a rebuild.... i have new disks and pads sitting in my room and was wondering what paint to use on the disks to simply keep the rust off...
ive seen it where the whole disk is painted and after some use its happy etc...
and then the calipers ill rebuild at the same time and paint them...
the simple question is which paint is best to use?
halfrauds high temp paint?
preferably a rattle can of sorts!
thanks chaps
ChrisT
Club RR Member Number: 225
painting calipers and disks? ChrisT
@christ
Club Retro Rides Member 225
Oct 11, 2011 21:18:25 GMT
never had a problem using hammerite (smooth) on calipers, not sure about painting the disc though, a coating of wd40 or similar will keep the rust off - just remember to degrease them before use.
RetroMat
Column Shifting!
Oct 11, 2011 21:18:37 GMT
I used satin black engine enamel when I rebuilt the brake calipers on my saab. They havent gone rusty yet! I did give the outside of the caliper a good go over with the angle grinder+wire wheel before painting.
will930
Oct 11, 2011 21:25:14 GMT
i see, just thought they get hot but not hot enough to poop the paint during road use i guess...
i may just use some plack on the disks to just keep the rust at bay
tontoe
Enter your message here...
Oct 11, 2011 22:18:41 GMT
PJ1 paints do really good quality hi temp paint in a can normally used on motorbikes its not the cheapest but lasts better than most
life is just a game we play
spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
painting calipers and disks? spiny
@spiny
Club Retro Rides Member 167
Oct 11, 2011 23:10:28 GMT
if you're keeping the disks inside, unless you're not planning on fitting them for fifty years, then they'll rust less than a set on a car thats been parked up for a weekend in wet weather.
will930
Oct 11, 2011 23:21:46 GMT
huh? they will be on the car asap....
spiny
Wiki Admin
@spiny
Oct 11, 2011 23:25:14 GMT
huh? they will be on the car asap.... ok, i'm confused, why are you wanting to paint the disks ? the paint will rub off the first time you use the brakes and probably clog the pads for a few miles as well.
Last Edit: Oct 11, 2011 23:26:03 GMT by spiny
mitchy
Oct 13, 2011 21:58:17 GMT
ok, i'm confused, why are you wanting to paint the disks ? the paint will rub off the first time you use the brakes and probably clog the pads for a few miles as well.[/quote]
This
Why would u be painting the disc's?
And ive used halfords high temp paint that comes in a tin so you can brush it on and never had any problems.
bl1300
Oct 14, 2011 13:02:58 GMT
I'm taking it that he wants to paint the hub of the disc rather than the bit the pads act on cause I cant see any reason for painting that
Current fleet.
Oct 14, 2011 19:47:10 GMT
I use smooth Hammerite, works great. High temp paint might work better on the disc centres, I am guessing you're wanting to paint the centre of the disc and not the part the pads are in contact with..
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
will930
Nov 13, 2011 14:16:18 GMT
Well to avoid any rusting on the disk i used wheel silver on the entire disk not concentrating on the contact area
So the outer lip is painted too, but i want it so that theres a good line where the pads go!
So my question is will it be ok to let the pads remove the paint when bedding in so i get the crisp line or scrape the worst off?
Nov 13, 2011 14:26:11 GMT
You might gum the pads up a bit (depending on how much overspray is on the contact area)
It'll probably not cause a major problem, but personally I'd just remove as much as you can, either by wiping it off with thinners or some 320 ish sandpaper.
Nov 13, 2011 14:26:12 GMT
IMO i wouldnt have painted the disks on the contact area at all, But i cant see there being an major problems in letteing the pads do the work to remove as it wont have adhered properly in the first place. I have had a car stood for almost 2 years with only wd40 on to prevent rust and after a couple of miles they were gleeming.
will930
Nov 13, 2011 14:31:01 GMT
Ah yeah as there small disks a bit but ill get some thinners on there and paper to remove the worst! But I'm leaving it to cure as long as possible to make the paint more flakey so it shouldnt gum up too bad!
will930
Nov 13, 2011 19:47:03 GMT
So my answer is to remove the worst and its fine?
painting calipers and disks? BenzBoy
@benzboy
Club Retro Rides Member 7
Nov 13, 2011 20:59:39 GMT
Just take all the paint off. I don't understand why you'd be worried about the very edge of the brake discs going rusty - most of it will be covered by the calipers and splash plates, and the centres of the brake discs (the ONLY bit I would even consider going near with paint) is covered by the wheel. In my opinion (and I'm employing a little common sense here): Painting calipers: Fine. Painting brake discs: Not fine. Dangerous.
Last Edit: Nov 13, 2011 21:04:25 GMT by BenzBoy
will930
Nov 13, 2011 21:40:21 GMT
I don't get why its dangerous? As my car has no covers around the brakes and i hate seeing it rusty
@benzboy
Nov 13, 2011 22:06:19 GMT
But you only see the very edges of the brake discs when you remove the wheel. Any part of the brake disc visible through the holes in the wheels when fitted is a friction surface and so needs to be free of any contaminants - grease, oil, brake fluid, paint - as it affects braking efficiency and is thus dangerous. That's why when you fit new discs you have to clean the oily coating off (the coating which stops the discs going rusty), as otherwise the contaminants will get burned into your brake pads and affect their performance. If you're worried about the friction surfaces going rusty then just drive your car more, the braking will polish them up just great.
Nov 13, 2011 22:12:08 GMT
If you want pretty brake disc centres... I guess it would be ok to paint the discs if you completely cleared the contact area before use. The paint could clog or even contaminate the pad material.
I've got Rovers.
