Oct 11, 2011 20:41:40 GMT
Does anyone know of any good bearing suppliers? I'm looking for about 10 60012RS bearings, SKF/INA or FAG branded. All the usual places I look want silly money
Oct 11, 2011 20:45:15 GMT
Unfortunately unless you can find something common that uses that bearing it will be expensive. Have you tried simplybearings?
Oct 11, 2011 20:46:23 GMT
Last Edit: Oct 11, 2011 20:53:08 GMT by Adam
Oct 11, 2011 20:49:28 GMT
I haven't got a specific recommendation but Google shopping seems to be pretty successful. I didn't look at the manufacturers but it has to be worth a trawl
Oct 11, 2011 20:52:50 GMT
It's a common bearing. My application is for Hope XC Mountain Bike hubs.
It's just a bit daft when you try an order 6 and it's about £25! I just didn't know if you guys had a super secret bearing suppliers that might make the cost a bit better.
I was hoping to get it under £20. (skint you see)
Last Edit: Oct 11, 2011 20:53:40 GMT by Soopahfly
Oct 11, 2011 20:54:53 GMT
It's a common bearing. My application is for Hope XC Mountain Bike hubs. It's just a bit daft when you try an order 6 and it's about £25! I just didn't know if you guys had a super secret bearing suppliers that might make the cost a bit better. I was hoping to get it under £20. (skint you see) £25 for 6 sounds pretty good to me for SKF gear.
Oct 11, 2011 20:57:38 GMT
Last Edit: Oct 11, 2011 20:58:52 GMT by ben711200
Oct 11, 2011 20:58:01 GMT
Fair enough. I'll strip down my hubs/freehub and see just how many I actually need.
Oct 12, 2011 14:03:07 GMT
purplevanman
Way too orangey for crows
Oct 12, 2011 21:23:35 GMT
Oct 12, 2011 22:05:55 GMT
Oct 12, 2011 22:53:11 GMT
have you tried city seals & bearings?
theres more to life than mpg & to much power is just enough.
Fair enough. I'll strip down my hubs/freehub and see just how many I actually need. You'll need four, two in the main hub body & two in the freehub itself, but the inner one site behind a circlip, so don't try & press it out until you've taken that out. Also watch for the spacer in the freehub body & between the freehub & main hub body as they're different sizes.
Oct 13, 2011 14:24:25 GMT
Fair enough. I'll strip down my hubs/freehub and see just how many I actually need. You'll need four, two in the main hub body & two in the freehub itself, but the inner one site behind a circlip, so don't try & press it out until you've taken that out. Also watch for the spacer in the freehub body & between the freehub & main hub body as they're different sizes. This I know I was meaning how many actually need replacing. It was rebuilt not long ago, but it's started dragging.
Oct 13, 2011 17:24:52 GMT
Usually two if it was done not long ago, the inside one in the freehub body & the drive side in the main hub body. They always seem to get water in there down past the seal & wreck those before the outer pair.
longman
Club RR Member Number: 3
Bearing supplierslongman
@longman
Club Retro Rides Member 3
Oct 13, 2011 17:39:19 GMT
Paul 98 500 SL 86 911 Carrera/sold 23 Octavia Phev
