i need to hook up my solenoids i have 3 per pump 4 pumps in all ,, i cant figure out how to wire them up an i also need to know how to wire up every thing Else besides switch bored battery's,pumps,solenoid if u got a step by step diagram that would be great
A little more info on what you are doing, and what parts you have would also be good..... (I'm guessing air)
Dez
Club RR Member Number: 34
nah, its hydros by the sounds.
depends how many batteries you have as well really, and how youve got them banked (12/24/36/48V), as this will effect how you connect your solenoids. I'm guessing if youve got 3 sels per pump then youre running 36v, as either 6 or 12 batts?
theres some pretty good diagrams on layitlow.com that are as good as youll get.
Last Edit: Oct 9, 2011 22:44:05 GMT by Dez
