Hi I'm in the process of looking into fitting the cosworth electric servo set up using the cossie callipers aswell so all matched up has anyone on here used one of these or can point me in the direction on any threads disscusing this any info welcome cheers Adie
dowot
fordpower and powered by ford are two forums that i know have covered that in the past..
bortaf
I know a bloke uses em in 24V cossie conversion on cortinas he just runs an ign live via a relay to run em, try the sierraownersclub forum if the abone 2 don't work out (it's older and has more archives than those 2 but you may need to join the club to see all of them )
R.I.P photobucket
Oct 10, 2011 12:07:21 GMT
Cheers for the replies fellas appreciated Tried having a look on them sites but couldnt find the threads I need found a few asking the same questions as me. Ill have a trwal again tonight I have found that there are two differnt types so have another on its way as brake pipes servo pump and res are on opposite sides I'm hoping to split the units and bolt the pump nearby and have a longer banjo pipe made to assist, have found out that the sphere is nitrogen filled at very high pressure and the pump pressures up on start up,Ive got a mate whos fitted one to a rally car so can get the correct wireing diagrams but would just like to find out more from others that have gone this route and any pitfalls I may come up against Adie
