The carburettor end is not a problem but I'm having trouble figuring out a way to set up the pedal end so that when the pedal pulls and rotates it doesn't put a localised stress on the actual cable by pulling downwards against the ferrule.
I can't use a long lever to pull the cable because of lack of space so I'm thinking of making some kind of linkage system between the pedal and the end of the cable.
Any ideas?
Ta
Any ideas?
Ta
