325 high comp engined 325 touring in lach silver, ive had this car for over a year now and has served me great, used it to do weekendly 250miles commutes and has been my daily driver.
has over 11 months mot, taxed until the end of the month, can tax at cost.
It has a single point lpg kit fitted with tank in the spare wheel well, hidden filler, so no nasty holes in the body work and has a almost new r90e vaporizer, LPG is 70p a litre here so the savings are great, ive set it up with a wideband lambda so is running teh correct misture on lpg. It starts on petrol but can be switched over to gas straight away from cold or hot by reving over 2000rpm, only time I run on petrol is to start or if ive run out of gas(can choose to run on petrol only with switch. Tank holds about £35 of gas and this gets me 240 miles driving malvern and back with cruising and some speed runs.
cars done over about 160.000 miles but runs great, and is solid, only has had one piece of welding done on the front jacking point, has this done prior to the mot. car ius lowered 60mm, it is rather low I think, its has a custom sump guard fitted on the front tho so avoid any sump damage, could do with some larger profile tyres on the front imo.
has a powerflow exhaust sytem which is not much louder than the standard system, its not a loud system imo, its nice and quiet cruising. Has an immob fitted.
its a high spec model with option extras, its got electric windows, electric mirrors, headlight washers(don't work), speaker fade, did have heated seats from factory, electric sunroof, has air con aswell, altho will need a re-gas.
bad points.
fuel needle doesnt work, its up and down erratically, but the fuel light does work so no issues of running out. have spare clocks which should solve this.
front seats do not match rears.
drivers door and passenger wing are a poor colour match
has a small rust patch on the sunroof panel.
drips abit of oil aswell, only needed to top it up a few times, its not a bad oil leak.
run rough on petrol when cold, its fine once warmed up, I run it on gas so have no investigated it.
its a great car and ill probally regret selling but ive got my self a truck again and with a land rover also and a beetle project drive space is lacking.
car is located in sheffield and I am looking for £1000
bad points.
