bl1300
Sept 25, 2011 8:24:00 GMT
Reading through the I cant believe how bad this is thread I thought that perhaps something constructive could come of it.
So here we are. A place for the welding experts on this forum to honestly advise those just starting out.
So ask your questions perhaps post a pic of your work for advice. The only thing I ask is constructive critiscm only but do be honest. If something is bad say so.
i.e Thats curse word!!! (No thanks)
That not got decent penertration try adjusting wire feed and power settings (Yes please)
My question.
I have just purchased a DC gas/gasless welder. What is the best way to set it up for welding bodywork?
I do my work outside so have been using it gasless. Is this a good idea? I also find that everything is covered in a grey powder after welding is this normal?
Current fleet.
oldchap
just hanging about
Sept 25, 2011 8:46:15 GMT
what's that awful noise
Sept 25, 2011 8:51:16 GMT
agreed on the auto helmet , makes a massive differance
best bet would be to ask if theres a local member that can weld well to pop round and show you how to ajust the machine and what a good /bad weld looks like
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Welding advice thread.ToolsnTrack
@overdrive
Club Retro Rides Member 134
Sept 25, 2011 9:16:40 GMT
Try and run gas wherever possible. Be serious about how much welding you are likely to do. If you are serious about learning and predict you are about to start a lot of welding (or own an Alfa Romeo, basically) consider hiring a bottle of gas rather than buying the small bottles from machine mart/halfrauds. They can become expensive if you start to weld a lot.
If you get an auto helmet, be sure to keep it maintained. They can run low on juice and start to lag on response time for dimming, and can on occasion leave you with Arc eye.
I also agree with Steve, get a friendly experienced person to check your work and give you pointers. If you have no experience it can be very hard, time consuming and frustrating to establish that your welding is up to scratch.
sparkyt
selling stuff
Sept 25, 2011 9:55:50 GMT
Best advice I can give to any one starting on welding on cars is don't be shy cut out all of the rust . All of it . Get back to the good metal . Buy the best panels or repair panels you can as the thickness of the metal is what your looking for .. I'm in Birmingham . Welder setup and ready to go . If your close buy I've got no problem showing some of you lads how to set up and start welding . Give out free advice . But please don't ask me to help you weld up a metro I do have standards
Sept 25, 2011 10:09:14 GMT
'03 Porsche 996 C2 3.6 - Sort of Retro '84 Porsche 924 - Definitely Retro!
sparkyt
selling stuff
Sept 25, 2011 10:11:23 GMT
Yep . Nice looking mask
Sept 25, 2011 13:50:30 GMT
Best to get a good quality mask, like speedglas. Yeah its more expensive, but when its something as important as your vision, you really do want the best
1939 Francis Barnett Powerbike 1971 Honda C90 1992 Mitsubishi Lancer 1.5 GLX 1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van
Sept 25, 2011 15:44:34 GMT
An Auto dimming mask is a fantastic addition to anyones setup, although it is not the be all and end all. It helps hugely when doing car bodywork, but for welding chunks of metal on a welding table I would personally reach for my standard mask.
Preparation is key. Weld will not stick to/penetrate rust, paint etc. Get a wire wheel and flap disks. My personal preference is to wire wheel the area, then flap wheel the edges that are to be welded together.
Get some bits of 2 or 3 mm steel sheet and practise welding with those. It is very forgiving and quite easy to start to get decent welds. Welding bodywork is HARD. I wouldn't suggest practising on bodywork or thin steel, you will get just really fed up. Give yourself a chance and start off with thickish scrap. Once you can lay down some decent welds and understand the basics of what you are doing on good metal, then try car bodywork. Oh and try wherever possible to weld down onto a flat surface, i.e. if welding on a bench, flip the work around so the joint to be welded is horzontal. It makes life MUCH easier.
If you can use a big bottle, it makes life much easier, altough little bottles are not the end of the world if you only weld occasionally.
My 2p worth.
Like anything PRACTISE is key, and practise does not meen half a hour before you let rip on your car. It means half an hour every few days for month or six.
Welding advice thread.HARDCORE
@hardcore
Club Retro Rides Member 190
Sept 26, 2011 13:44:54 GMT
Reading through the I cant believe how bad this is thread I thought that perhaps something constructive could come of it. Nice work Paul, thanks - moved to The Technical Bit..
Sept 26, 2011 14:11:57 GMT
Try and run gas wherever possible. Be serious about how much welding you are likely to do. If you are serious about learning and predict you are about to start a lot of welding (or own an Alfa Romeo, basically) consider hiring a bottle of gas rather than buying the small bottles from machine mart/halfrauds. They can become expensive if you start to weld a lot. About hiring gas bottles - I have been renting an air products bottle for about 5 years now, and I'm taking it back at the end of this month and not renewing. Why? Because there is a better alternative. The problem is that the rental is around £130 per year, and unless you weld a LOT you won't go through a full bottle in a year. I noticed from my invoices I average about 20 months on 1 bottle. There are now several companies offering pay as you go bottles for sale - £160 buys you a brand new (and full) one with a 10 year life and the cost of filling is about the same (£40 ish) so I'm getting one of those instead. Only bad point is my air prods bottle is still half full.
Sept 26, 2011 14:34:11 GMT
I uses adams gas for my gas. It's pay as you go but you get a proper 9L gas bottle not a little hobby one. I think it was £50 deposit for the bottle then £30 for a refill. It gets a bit pricey if you need to pay for delivery on top of that but they're opening re-sellers all over the place now. There's one in Edinburgh so when I'm over that way I just go in and get a re-filled www.adamsgas.co.uk/index.php?option=com_virtuemart&Itemid=54Gas makes a big difference. I'm now chopping out a lot of the stuff I did when I was using gassless and re-doing it as it's so much easier to get a nice weld going. I found your surfaces have to be really clean with gas but the gassless stuff is a little more forgiving. The Autodimming helmet is a must but buy a decent one as I bought a cheapo one to start with and the friggin thing stopped auto dimming! Also 1mm grinder cutting discs are da-bomb. They make cutting out metal so easy compared to the big thick horrible cutting discs you get from halfords.
Dez
Club RR Member Number: 34
Welding advice thread.Dez
@dez
Club Retro Rides Member 34
Sept 26, 2011 16:28:42 GMT
I cant really be bothered to give advice on welding itself, theres so much out there it would be pointless.
but, when it comes to price of equipment, BOC is still cheaper than anyone else for gas(and just about everything else too if youre buying quality gear not cheap sh1te). I use a size Y- about 3.5 ft tall argoshield light (purely so I don't have to lug a fugging great 6 foot bottle around to get it refilled), and its £45 a year rent and £25per fill. afaik nowhere can get anywhere near that on price. its marginally more expensive than using the size X I think it is big bottle, but its only a couple of quid, I get through about half a dozen a year.
they're offer an account service, so you can have now and pay a bit later, which the others don't offer- handly if you run out of something/ blow equipment up halfway through a job and you don't get paid til its done (the joys of being self employed!)
all the own brand stuff they sell is great quality, and competitively priced., mig tips, shrouds, eurotorch parts, cutting discs, etc. etc.
the above autotint is just cheap curse word. buy a speedglas, or of you cant afford one of those get one of the red BOC own brand ones. they're designed and made by the other european optics manufacturer that I cant remember the name of, are great quality, and are about £100. more importantly, all parts are available as consumables. ive had one for a couple of years, and its as good as a speedglas just cheaper.
Last Edit: Sept 26, 2011 16:30:29 GMT by Dez
Sept 26, 2011 18:25:16 GMT
Two things I would offer advice on, specifically because its alternate to most of whats been said. If you are new to welding, and don't expect to be doing a huge amount, you really, really don't need a big bottle of gas, or a contract or anything. I've welded parts on three or four cars with one 900 disposable bottle which cost about £13 last year sometime. The other thing is that you shouldn't get overcome by a need to get a auto-tint mask. much as I'd love one that works, I searched for a long time for the fastest acting one i could get under £250, and took it back within 3 days, as it didn't react fast enough. I have bad enough eyes without arc-eye. My eyes are safer welding without a mask rather than using the tinting.
Oh, always make sure there is no rust at all on your wire. It's cheap, so replace it if necessary. And a good quality welder will help massively.
bl1300
Sept 26, 2011 19:01:58 GMT
I always use a hand held mask. Just don't like those head worn ones. They always get in the way.
each to their own and whatever you find preferable I suppose.
Mind those crappy ones that come with welders are useless but a decent quality hand held one is fine
Current fleet.
spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
Welding advice thread.spiny
@spiny
Club Retro Rides Member 167
Sept 26, 2011 19:22:13 GMT
^ same here, I just feel more comfortable with the little handheld mask that came with my original welder years and years ago - on my third or fourth set of glass though, and it's now screwed together properly, not the stupid plastic clips it came with also seconding the 'cut it all out' post above - i'm about ten years into my van 'resoration' (i see it about four weekends a year) and i'm re-doing some of the postage stamp stuff that I did at the start when it seemed a good idea
Last Edit: Sept 26, 2011 19:24:16 GMT by spiny
Sept 26, 2011 20:30:40 GMT
I'm no pro but I have a few tips I started the wrong way round - with a cheapo arc welder. While it's trying to run before you can walk, it's damn cheap (£20 buzzbox from freeads, £20 box of rods and off you go), and teaches you A LOT and very quickly. I'd recommend doing it this way because it's not a massive investment up front, and will weld down to 1.5mm with a little practice (2.5mm rods). COVER UP! - eg, wear sleeves. You'll get massive sunburn otherwise. I'm sure it cant be good for your skin all that UV! don't weld shut-eyed. Sounds simple but i've done it a few times where my mask was at the other end of the garage and I was holding all the pieces already. UV goes right through your eyelids and you get arc eye anyway - mental! PS - stick does corners very nicely
Last Edit: Sept 26, 2011 20:33:18 GMT by lolface
78 Kadett C 2.0 8 valve turbo, holset, rust&other stuff..
duncanmartin
Out of retro ownership
Club RR Member Number: 70
Welding advice thread.duncanmartin
@duncanmartin
Club Retro Rides Member 70
Sept 26, 2011 21:31:16 GMT
I did a little TIG welding on a course a couple of years ago, and bought a cheap inverter TIG set, but I've only just got a garage. I need to do a lot of welding on my Lancia (floor and sills first), and I'm wondering whether it's worth getting a proper Argon bottle and doing it all with TIG or whether I should get a MIG. TIG would take longer, and gas is more expensive, and MIG is supposedly easier. On the other hand, I have a TIG welder, and a vague idea what I'm doing. Also, there will be some bodywork after I've done the structural stuff... What do you guys think? Cheers Duncan
Sept 27, 2011 15:21:00 GMT
I use an Adams Gas agent for mix, and a pub bottle for thick stuff and cheapness. Cheaper for occasional use than rental.
Use a mask similar to abovfe, find it fine, had a SIFlite before which was excellent for the price.
I use think motorbike gloves the summer or "racing" type - plenty of 'feel', and they were there. Can be had cheap.
Earplugs for welding upside down to avoid that sizzling sensation, and a "snood" thing to stop hot rocks down the neck.
Join a welding forum and read the threads and questions, lots to be learnt there about the different techniques.
And don't start doing structural stuff until some good practice has been done. Very obvious but often see people piling into a chassis or something first off.
Sept 27, 2011 18:34:57 GMT
I know mig is meant to be easier but can stick (arc) welding be used for cars successfully? Also how feasible is it to weld at the roadside? I live at the end of a dead end so passers by would be rare but i done want to blind all my neighbours if they can see me out of the window. I can buy an arc welder for £20-30 on ebay. I will rarely use it so its not worth buying a mig. The other option would be to rent one but i would prefer to take my time and learn at home.
