Sept 26, 2011 12:57:50 GMT
Bought this a while back but other decisions I have made have meant it isn't going to work for me now. Dana 1031 axle from volvo 940, came off a car with knackered engine no whirring as far as I know. 5x108 pcd. 1500mm hub to hub (allow a bit more for disc fitment). Ratio of 3.54:1. What you see is what you get, one hub has no studs fitted I do have 5 but the ends are beaten to death Collection only, £40.
Last Edit: Sept 26, 2011 14:06:44 GMT by damien4884
1977 datsun 810 180b estate
Sept 26, 2011 14:14:14 GMT
Sept 26, 2011 14:45:17 GMT
Jonas Borgegård www.bakaxel.se/ writes that a number of 1031 housings don't have dual ribs. The 6 cylinder 260's use a 1031 with low numeric ratios eg 3.31, 3.54. You missed a bit, i've also seen 1030's with 2 ribs. Have a shot of the inner workings.
Last Edit: Sept 26, 2011 15:07:03 GMT by damien4884
Sept 26, 2011 15:11:11 GMT
sweet! nice bit of plug for the strength and out and out bargain that someone will get with this axle!
Quick bump before it goes on ebay
bruisercapri
black and blue and black all over
what's the width on this axle fella? might make a nice alternative to the atlas in my capri ;D
1500mm or 56 inches plus a bit for the disc flanges. Mk1 capri is 50 mk2/3 capri is 52. Quite easy to narrow compared to some other axles though
bruisercapri
am very interested fella as it would give me further options with my mk1 and means i could use my baby atlas on my 2.0s for fitting of wider wheels ........... ;D would it be ok to get back to you sometime next week about it?
now this is what you want to use on a p100 rather than a curse word capri axle and then spacers to get wheels to fit right lol. plus take transit adapters off p100 hubs on from and that gives you 5x108 too so matching pcds.
No problems, no one else has jumped on it yet.
bruisercapri
Oct 11, 2011 23:00:20 GMT
going to have a go with this i think fella ;D, just got to organise me coming down to you or if a mate will be in the area anytime soon, how do you want paying?
Oct 13, 2011 18:28:53 GMT
Cash on collection is fine with me unless you wanna pay then get a RR'er to collect through pony express, i can stick it over at my other garage out the way if you need a bit of time to sort out collecting it. Pm me and we'll sort something out.
