Aug 11, 2006 20:29:57 GMT
can anyone tell me the ratios to mix 2k paint with hardener and thinners?
ive used 1k and cellulose before but not 2k having a go with some tomorrow! ;D
btw it is 2k top coat, not base and lacquer
slater
Club RR Member Number: 78
Paint mixing ratiosslater
@slater
Club Retro Rides Member 78
Aug 11, 2006 20:40:57 GMT
I'm never quite sure, it semes to change depending on which paint you have.
When i painted the mini i brought one load of paint which i mixed 1:1 (i guessed) and it didnt require thinners. Yet the next batch of paint i brought would have been stupidly thin at 1:1 so i mixed it 1 part hardener to 2 parts paint. Both dryed fine.
If you do use some thinners with it then id try and keep it to a minimum as I'm told using thinners makes it take alot longer to harden fully.
Aug 11, 2006 21:18:39 GMT
Do yourself a favour, go buy some mixing cups. They are far cheaper than cocking it all up.
The 2pack clear I used was 2 parts paint to one part hardener and 15% thinners. But they can be anything up to 5:1 - it will say on the can or on the data sheet.
If you really are too tight to buy mixing cups get a jam jar or similar container with STRAIGHT sides and a length of wood or scrap steel. Get a ruler and measure 5 cm, mark it here and then 2.5 cm above that. Put it in the pot when you mix the paint and fill up to the first line with paint, then up tot he second with hardener. You'll need to do the maths for 3:1 4:1 or 5:1 and also where to put the 10%/15%/20% mark as appropriate.
Mixing cups really are the way forward.
2K really fvcks up bad if you get it wrong and is like concrete to sand down so get it right, don't just guess.
And wear appropriate safety equipment. I was about ready to puke my guts after spraying 2K clear and I took "mostly" the right precautions, sort of.
Never again.
Last Edit: Aug 11, 2006 21:18:56 GMT by akku
Aug 11, 2006 21:21:19 GMT
can anyone tell me the ratios to mix 2k paint with hardener and thinners? ive used 1k and cellulose before but not 2k having a go with some tomorrow! ;D btw it is 2k top coat, not base and lacquer Use whatever the Data sheets for the particular paint advise, and use their mixing/measuring sticks as well Seriously, when it all goes wrong with 2K its a sh1t load of work to put right again....
Aug 11, 2006 21:43:19 GMT
hmm i see. will seek advice from the guy who owns the booth I'm gonna use!
we have mixing cups and a proper paint measuring stick so we'll see how it goes.
Aug 12, 2006 10:05:51 GMT
Oooh ooh ooh and don't buy cheap 2K either. The last thing you want is unpredictable paint. Go for Lechlar, PPG, Max Meyer or other brand you have heard of or been recommended to.
As a starting point Jawel who advertise on eBay is particularly rubbish. Avoid like plague.
Aug 12, 2006 12:14:20 GMT
I only use lechler and house of kolor. But thats because thats what our local paint shop sells, always buy from someone you can shout at in person if it goes wrong! If your in a booth and have all the measuring cups and stuff you should have no problems.
