Ciao Retroisti....
Last night I pciked upp the Shop Hack from Hot Rods by Max, he fitted a set of Felicia 40mm Corbra lowering springs and new shocks up front and a set of Golf 4 30mm (lowers an extra 20mm on a Skoda) Cobra springs rear, sadly my parts dude could not source me a set of Opel Corsa (shorter than Skoda) shocks for the rear so I'll fit them later, Max also stuck some 10mm distances inside the rear wheels. Sure it's not as low as it could be but it drives real nice, I loaded a GSXR K5 in the bed last night and went for a spin and man is it a huge difference from last year with cut down stock springs, it handles!!!!
I will drive it for a while to see if it comes down a bit in the front, if it don't I'll cut a bit in the spring since I want it lower in the front but the rear is perfect concidering I'm towing trailers and loading alot of stuff in it most of the time.....
So tonite I'll fit the Moon Discs and give it a general cleanup, load up the Chrome Chopper, a couple of digi snappers and tomorrow it's of for some serious cruising Downtown Stockholm.....
DP says: Stay tuned for pix from the event.....
