Sept 22, 2011 17:32:49 GMT
Hi all,
Does anyone have any experience of the best way to remove a section of mastic. I only need to remove a small section of the mastic inside the boot but it's proximity to the petrol tank makes me a bit nervous of hot air guns. any idea?
Sept 22, 2011 20:22:34 GMT
Wire wheel will have it out. If you're worried about sparks then a nylon wheel would also have the same effect (albeit less abrasive).
1994 Rover Metro 1994 Peugeot 405 Estate 1991 Rover Metro Gti 16v 2001 Fiat Seicento Sporting 1999 Fiat Punto 1.2 1994 Peugeot 106 Xnd (x3) 1991 Westfield 7 2004 Landrover 110 SW 2003 Seat Ibiza 1.9Tdi Sport 1959 Ford 107e Prefect 1992 Suzuki Vitara 2008 Skoda Fabia
madmog
Club RR Member Number: 46
Removal of Masticmadmog
@madmog
Club Retro Rides Member 46
Sept 23, 2011 7:44:42 GMT
Maybe bath sealant remover? Usually at the DIY stores next to the bath sealants. It's messy though as it dissolves the sealant to a nasty gloop
Sept 23, 2011 9:07:04 GMT
I'd go for the wire brushes in a drill or angle grinder too
Sept 23, 2011 13:28:01 GMT
thanks for the advice, chaps :-)
da6t
Dec 22, 2011 21:50:45 GMT
You'll still get sparks with a wire brush!!
Dec 23, 2011 23:28:33 GMT
There are 2 sorts of "Mastic". One is silicone, one is Polyurethane. There are effectively more sorts, but this split is effective: If it is Silicone, heat will not affect it. This is the very rubbery stuff that `usually`smells of vinegar when applied. the only real way of removing this is mechanical. My way is to sharpen a paint scraper and slice it off.
Polyurethane goes soft when heated - but very sticky. I use a poly-wheel, usually known as an "Easi Strip" for this.
Dust sheet over the tank area if you are still not sure.
'83 GTM Coupe. 4A-GE Powered '00 GTM Libra Auto. Ick. '71 Detomaso Pantera. Current Resto '89 GMC Safari Tow/Kip bus '05 SAAB 9-3 Daily '71 Siva Moonbug. Not even contemplating resto yet.
