Sept 22, 2011 15:20:28 GMT
Hi guys i have a citroen van 55 plate with a 1.9 diesel engine none turbo, its done just short of 110k which for one of these engines is nothing. rite....from cold i can let the glow plug light out and wait even for upto 25-30 seconds and struggles for ages, i can do this sometimes 3-4 times now once the van is started it runs mint, ie no leaks overheating etc...i can turn it off and start it with no probs all day if i leave it for around 4 hours it will start from when the glow plugs go out. BUT if i leave it for around 8 hours or more it starts to struggle again id like to add ive recently fitted new glow plugs and its still the same I'm wondering if the oils too thin, or maybe the injector is shot its doing my head in now, and don't really wanna just keep spending on parts to cure the problem, I'm just wondering if anyone has had or knows about these issues much appreciated
power is nothing without control
Sept 22, 2011 16:52:59 GMT
Sounds like a possible injector on the way out if its common rail. You'd need to have a leak off test done to confirm it though.
R.S. Autotech. Servicing/Repairs/Diagnostics.
Sept 22, 2011 18:41:49 GMT
had this exact same fault on a motor last year!! glow plugs changed just the same, so did a voltage check and nothing to the glowplugs even though the glow plug light was on for its normal time? anyway long story short I traced the wiring(and there is a lot of it in them) lifted up and seperated the fuse box as there are relays under there but nothing amissand lo and behold after removing the nearside headlight i came across a small box that was burnt on one side, turned out to be glow plug relay, unplugged it bought another one with the same umbers on it plugged it in and voila we had power to the glow plugs and normal operation was resumed!! since did another one and the box was in a totally different place!! mind you one was a peugeut and tohter a citroen but they have the same running gear etc? strange !!
Sept 22, 2011 19:48:34 GMT
Normally caused by a glow plug burning out and creating a short to earth. Normally this will cause the glow light to stay on all the time or flash, but good point, well worth checking.
Sept 22, 2011 23:55:56 GMT
another one here for thinking it may be the glowplug relay! And just because you may hear it click, doesn't mean it's WORKING either
Sept 27, 2011 17:07:04 GMT
thanks for the helpfull reply folks
ive had all the above checked, and there all seem to be working??
bortaf
Sept 27, 2011 20:19:22 GMT
ford 1.9as suffer from this when they start to loose compression, but TBH it's not a pronlem i've had with the pug 1.9? if there uis deffo power at the glow plugs and they are new i'd possably susspect an injector OR the cold start device/advance.
R.I.P photobucket
Sept 30, 2011 6:54:36 GMT
^^thankyou, i did suspect compression loss. but its now sorted
cheers guys
Sept 30, 2011 10:06:29 GMT
What was the problem in the end? Seems a shame to fix it an leave us on a cliff hanger!!
1994 Rover Metro 1994 Peugeot 405 Estate 1991 Rover Metro Gti 16v 2001 Fiat Seicento Sporting 1999 Fiat Punto 1.2 1994 Peugeot 106 Xnd (x3) 1991 Westfield 7 2004 Landrover 110 SW 2003 Seat Ibiza 1.9Tdi Sport 1959 Ford 107e Prefect 1992 Suzuki Vitara 2008 Skoda Fabia
Sept 30, 2011 10:46:11 GMT
Citreons have been found to leek air into the fuel filter housing which means you have to turn it over a lot before it will fire up, air can leak through the water drain because the seal fails.
Citreons have been found to leek air into the fuel filter housing which means you have to turn it over a lot before it will fire up, air can leak through the water drain because the seal fails. sorry guys, ^^^this was exactly the problem
