Sept 19, 2011 9:30:33 GMT
Hi all, I'm sticking a 2.0 litre supercharged, throttlebodied zetec in to my morris minor and wanted to know if you could have two maps on an ecu one for some sort of super eco mode and then a 'sport' sort of button where it engages my supercharger clutch and increases my fuel and stuff like that, you get the picture. I have not looked into it fully but was wanting to use some sort of megasquirt system.
Any help will be awesome!!!
Cheers.
Copey
Sept 19, 2011 10:15:56 GMT
your best bet is probably to get in touch with companies that do custom maps, i cant see why it couldnt be done though
Sept 19, 2011 10:22:27 GMT
In short, yes With megasquirt, you can have table switching - on a switch! So you have 2 fuel and 2 ignition tables. Flick a switch, and it goes from set 1 to set 2. Easy in theory, in practice - a bit of a pain. The easiest option is just to map it properly in the first place. If the maps are good, then you'll have both power and economy in 1 set of tables, with no danger of melting anything if you have the wrong set selected . See the way the tables work is pretty clever if your using speed density method - the modes of operation of the engine are pretty clearly defined, so there is a 'power' area, a 'cruise' area, an 'idle' area etc, and they should all be optimised in a good map, without affecting each other. Megasquirt allows you to control anything by defining 1 or a pair of rules, so in theory you could hook your supercharger pully to come on when your throttle is 90% closed AND your engine is at least 60 degrees C for example. It's just a low-level logic output coming from the board which you can control anything with, by adding a booster circuit. Exactly what sort you need depends on what sort of device you're trying to switch.
78 Kadett C 2.0 8 valve turbo, holset, rust&other stuff..
Sept 19, 2011 10:57:24 GMT
Awesome, cheers. I'm extremely far off from doing anything like this really, I'm just sort of trying to do alot of research before i screw stuff up later on.
Sept 19, 2011 11:49:22 GMT
If you don't mind flicking a switch when you want more power, you can make a manual override for the megasquirt controlling the charger. If the measuring and mapping is properly done, the megasquirt will be able to adjust to charger/no charger and you will get the economy you want.
Sept 19, 2011 11:51:00 GMT
Emerald ECU's have a triple map facility these days and seem to be well regarded, albeit much more ££ than Megasquirt
Sept 19, 2011 12:49:35 GMT
this can all be done with megasquirt.... but you would question the point of it really - I was going to run an eaton m90 on a mag clutch with table switching for my original 2.5l engine but that was purely because it would be show-y and a unique challenge.
The trouble is in building the boosted engine to get high power from the supercharger you end up with a much less efficient engine when the charger is off, this coupled with the fact that you need an intake that bypasses the charger (probably a far less efficient route than on most standard NA inlet tracts) means that the actual economy you gain is smaller than you'd hope.
If you want an engine that is "economical" (evidently you don't want economy too much or you'd have a diesel) and nice to drive then the best bet is to build the engine (supercharged or not) to your power expectations and then map it very well. As mentioned above, a good speed density map will be economical for cruise and high power for foot down times.
- '80 Mk1 Vauxhall Cavalier Saloon, 3.0l 12v... in progress with some special plans ahead - '94 106 Rallye, Endurance Rally Car
Sept 19, 2011 15:23:18 GMT
ok, cheers guys.
mk2cossie
Club RR Member Number: 77
ECU with 2 maps.mk2cossie
@mk2cossie
Club Retro Rides Member 77
Sept 19, 2011 18:58:43 GMT
if you only want the charger to come in at a certain rpm/load, then you don't need a switchable map at all...just need to properly set up 1 map so that when cruising (light throttle loads) the charger is off, then above a set throttle position you have the charger kit in and the fuel/ignition tables adjusted accordingly ;D
Sept 19, 2011 21:36:30 GMT
Switchable maps were designed for multi-fuel situations and make life harder imo. Losing at the lights to some kid in a fiesta because you've forgotten to switch on 'uber mode'. That offsets any rep you might have gained with your female passenger for having a 'uber mode' switch
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
ECU with 2 maps.speedy88
@speedy88
Club Retro Rides Member 118
Sept 19, 2011 22:14:07 GMT
Was thinking about doing the same with the williams ECU as I've got a fuel saver map which doesn't always play ball. Worked out I could switch it physically or even use a 256bit eprom rather than 128bit to switch internally. Lot of work though. Just learned to tweak the car so it runs properly on the one chip. Still getting there.
Sept 19, 2011 22:17:13 GMT
but uber mode sounds so fun!!! also i was thinking of putting an exhaust bypass on it too so once uber mode was engaged it would sound like a fire breathing dragon, also make the suspension drop 100mm so its on the floor and make my subs in the back louder than an aeroplane taking off and make it turn all of my neons and disco ball turn on......... noooot, i just want it so when driving to the shops or something its good on fuel and pleasent to drive, then for at the track just a complete animal, basically i want the best of both worlds rather than having two cars...
Sept 20, 2011 10:09:29 GMT
nitrous or even a nitrous assisted turbo might be better then trying to re-create mad max, clutch engaged superchargers don't work for proper engines (read V8's) getting one to work on a small engine hardly seems worth it, and its not like it'll be pokeing through the bonnet for all to see, saw a twin turbo'd 3.5 ltr v8 in a moggy once, quickness/loudness is controlled by the right foot
Sept 20, 2011 10:16:13 GMT
clutched supers can work... but it is not a cheap endeavour.
For what the OP wants then I say build a good engine (i.e. don't cam it to within an inch of its life) and then map it properly.
Sept 23, 2011 15:53:28 GMT
Switchable maps were designed for multi-fuel situations and make life harder imo. Surely turbo applications could benefit? i.e. if you wanted to be able to run switchable boost, also run 2 (or more) fuel maps, and drive boost control from these maps - i.e. map A 15 PSI of boost and not much fuel, map B 25 PSI boost and more fuel?
bortaf
Sept 23, 2011 20:01:15 GMT
Emerald ECU's have a triple map facility these days and seem to be well regarded, albeit much more ££ than Megasquirt Dave walkers column in PPC he mentions economy maps and full power maps, from wkat i've read he overfuels it bit for the full power mode to be safe on forced induction instals ?
R.I.P photobucket
Sept 24, 2011 22:31:41 GMT
Naah dude, that's what I call a complicated mess. I think if you wanted to have different boost levels on a switch, you'd use a boost controller with that functionality, and have the tables mapped safe to the highest boost that your machine can take. Typical scenario: In positive manifold pressure your maps are slightly to the safe side of 'just right'. How big the margin of safety is down to your and your mappers confidence in the engine. Your mapper will know from their experience and tools at their disposal how much is too much . Fuel wise - leaner than this gives more power, but nears self-meltdown. Spark wise, more advanced than this will give you a bit more power and will start to knock and det, leading to bent rods, blown headgaskets and pitted pistons/chambers. In the same way, in vacuum when would you need 2 separate fuel/ignition tables, when the 'right' set will offer you the best power and economy . Leaner than this will make your engine and EGT's hotter. More advanced is same as in boost you'll be reaching knock threshold and probably det, blowing your gasket. KISS = Keep It Simple and Sideways ;D not be thinking about what mode you're in all the time.
Last Edit: Sept 24, 2011 22:41:53 GMT by lolface
will930
Decked K11 Micra - RetroRunner Mk2 Golf
Sept 24, 2011 23:34:16 GMT
niztune can easily have many maps saved and just easy swap them over for mots and different running etc
