Odin
So, there I was rotating the tyres on the Datsun this morning. Got the front offside wheel off (I hadn't had a prod about in there until today) and noted the spring cup was a little flakey. Probably just the underseal peeling off a bit, I thought. No biggy. Actually, no. A prod revealed a rather large proportion of the cup skillfully crafted from filler! WTF is with that?! I don't mind a bit of 'comedy' bodging (oh look, this whole door is made of filler, LOLz, etc) but how did this pass an MOT in the past few months?! Anyways, that's brought plans forward a bit sharpish and I'll have to put my ideas into execution. This is the perfect excuse for new struts and springs all round that drop me significantly nearer the tarmac. ;D So, J-tin experts....where can I get the necessaries from and will they cost more than I've budgeted (ie not a great deal)? Ta chaps!
YOW! MoT tester must have found a £20 mysteriously wrapped around that component
Agreed, filler, chicken wire, old news papers etc. in doors, wings etc is something you accept but doing something like that is just crazy!
antdat
just cut the cups off and get a coil over kit from rally design and a pair of springs, job done and on coilovers too
Oh dear! thats terrible, however it will be loads better if you buy good struts and springs to add on. I'll be ordering KYB's from here but no listing about Datsuns, you could ask though.. www.buypartsby.co.uk/shock-absorbers.php
Odin
just cut the cups off and get a coil over kit from rally design and a pair of springs, job done and on coilovers too Do you mean those slip-on sleeves that they do? Are they any good? And could I get away with stock springs and those until I fancied going lower?
bstardchild
Club RR Member Number: 71
So, there I was rotating the tyres on the Datsun this morning. Got the front offside wheel off (I hadn't had a prod about in there until today) and noted the spring cup was a little flakey. Probably just the underseal peeling off a bit, I thought. No biggy. Actually, no. A prod revealed a rather large proportion of the cup skillfully crafted from filler! WTF is with that?! I don't mind a bit of 'comedy' bodging (oh look, this whole door is made of filler, LOLz, etc) but how did this pass an MOT in the past few months?! The bit that i don't understand (and this goes for carboar/newspaper/chicken wire sills too is why!!!! It takes ages to get filler and wibblepoo to look like it hasn't been bodged!!
Snoozin
Toyophile
That is quite scary right there!
Lucky you discovered it when you did I say.
Bioshock
It aint hip to be square.
'Kin crazy bit of bodging,the things people do to tart up cars for a sale
Almera GTI = ugly bird who turns out to be great in the sack = Win
tigran
In rust we trust. Amen.
Club RR Member Number: 142
Cost I presume BS. But agree that is bang out of the order. Wish my MOT'er wasn't a pedantic curse word and was as lax as that!
*is not at all bitter*
antdat
just cut the cups off and get a coil over kit from rally design and a pair of springs, job done and on coilovers too Do you mean those slip-on sleeves that they do? Are they any good? And could I get away with stock springs and those until I fancied going lower? yes but the ones i got i had to weld on the tube, you won;t be able to use standard springs here is a picture on one of mine complete with threaded tube The springs are about £15 each give or take, the kit is about £21.50 per side +vat www.rallydesign.co.uk/catalog/index.php?cPath=1358_532
Last Edit: Aug 10, 2006 6:49:39 GMT by antdat
