Rob
You know, for kids!
hey there all you knowledgeable cowboys and girls... I'm after some help. I'm wanting to 4 pot calipers to the front of my pickup as at the moment i need a gravel pit to stop the thing. what do i need to look for ? obviously i will be buying vented discs to accompany them. what are the important measurements i ned to look for or is it just a case of any caliper but the bracket to fit it will need to be modified / made? Cheers Rob ;D
Right. Basically it's best if you choose a matching disc and caliper off the same car and things are MUCH easier if it's got the same stud pattern or the same hub. So lets say you used a Mondeo caliper and disc on an drum-braked Anglia as an example, a bad example but it's an example.
The stud patterns are the same on both but the hubs are different due to the drum being part of it so you have two options: Either machine the outer part of the drum off leaving just the inner bit with the studs so that the disc can slide onto the outside, or use a hub off another car like an Escort which is a close fit but needs different wheel bearings to fit.
Now to fit the caliper. Take the drum backplate off the strut and you mount the caliper on a bracket on the backplate mounting points on the strut. Basically it's a matter of making up a template, offering it up and then shimming the caliper or spacing the disc so that it is in the righ position in or out.
It's not a difficult job but it's easier if you can use a non-floating caliper and if there are discs and calipers you can steal off a car of the same make with the same stud pattern. Then the original hub can be used etc etc.
Rob
You know, for kids!
Cheers jonny - it does have discs at the front at the mo...
It's 4.5in PCD - Ill check the PCDometer and see....
Honda - Nissan - Mitsu - Rover - Volvo (new)... I might have a word with my local breakers - surely something like a Rover 600 would have a decent caliper ?
Cheers Rob
Might be a bit of help.
I have a set of Toyota Corolla AE86
front caliper front hubs front disks caliper brackets
AE86 is 4x114.3 (4.5in)
the disks ar ok-ish and the ubs need new bearings and the calipers need a rebuild.
Rob
You know, for kids!
Might be a bit of help. I have a set of Toyota Corolla AE86 the disks ar ok-ish and the ubs need new bearings and the calipers need a rebuild. cheers mate - i'll give that a miss (for now anyway) only that if i ever need to replace bits, I'm sure ill be better off chasing parts other than sky high AE86 prices... bit too sought after. the offer is appreciated tho
no worries dude, and I know what you mean, I am building a KE70 using ae86 parts and it was cheaper to just break my ae86!! (its a J import and a bit battered!)
oh and to add,
You could use the MA61 Supra as they are 114.3x4 and am sure they have big brakes??
Princess 4 pots bolt onto the Marina uprights and work using the standard discs ... how do we know .... been there and done it Now running 3rd gen rx7 front calipers (huge squeeze cast alloy jobbies) and Escort RS Turbo discs certainly not a bolt on job and a bit of faff to get them all squarely mounted and a REALLY major job to squeeze them back under the 14" wheels (clearance ... yes but not much .... a few thou at most in a couple of spots )
Last Edit: Aug 9, 2006 16:56:23 GMT by mikelmr
oh and usually Marina's are 4x3.75" (or somthing equaly bizzare) ... I suppose the pickups are different ?
Thought Marinas were 4 X 4", same as Vauxhalls? My mate had Vauxhall Magnum wheels on his Marina pick up.
Sean
princess 4 pots are the answer to all. ;D www.brakeparts.co.uk/ this place has them listed new, whether they do or not is another matter. anyway, should be some help in pricing what your after.#
Rob
You know, for kids!
the pickups are different ithink - they're definitely 4x4.5 as i have triumph tr6 wheels on... yeah - i was trying to avoid princess ones - they seem to go for silly money !? booo......... cheers guys Rob
if that site actually has them they were about £62. thats way cheaper than some people want 2nd hand.
tigran
In rust we trust. Amen.
Club RR Member Number: 142
Fitting 'other' calipers...tigran
@tigran
Club Retro Rides Member 142
On this note I was wondering what thickness of sheet I need to safetly fit different callipers. Would something like 1/4 gauge be enough? to make up the bracket with?
if its 4x100 look at the brakes on a mk3 golf gti or calibra turbo? otherwise look at some 4 stud bmw's (E30) or 4 stud volvos (think there 4x100) there rather common around most breakers altho i don't know if there 4 pots! usual rule goes bigger the car the better the brakes! possibly a stupid question but did any other production bl car use princess 4pot calipers?
2006 Audi A3 2003 Fusion 2 looking for a project....
