Smiler
The Cortina was started up for the first time today and settled to a rather growl like idle. This is the first time the cars new engine has been fired up in it's new home. For those who don't know, I have been fitting a 2.9 Cosworth 24valve V6 to it. See www.escortupgrades.co.uk/Other%20Stuff/Cortina/Cooltina!.htm for details. It's not quite properly sorted, I had to rig the coil pack by giving it a direct live feed to make it work but at least I now know where the problem lies. Sounded great with just a pair of down pipes for an exhaust. Only gripes were a suspect air leak with sluggish throttle response and run down and one noisy tappet that I knew about before installing it. Next on the list will be an accelorator cable (2.9 Sierra or 2.8i Capri) and a type 9 V6 spec clutch lever boot. Then sort the brakes and LPG kit. Anyway, chuffed as nuts!!! ;D
Last Edit: Aug 7, 2006 21:28:47 GMT by Smiler
Seth
Best feeling in the world ;D ;D Well done!
woo hoo. how long do you think to finish?
Smiler
Cheers, a little while yet till it's finished but got a huge dose of enthusiasm again now! I still need to source some capri 2.8i front discs for the brakes and rebuild the master cylinder. Suspension is already on polybushes byt the rest is old standard kit. Also need to sort an exhaust system!
Bioshock
It aint hip to be square.
Nice work fella
Almera GTI = ugly bird who turns out to be great in the sack = Win
well done bud, could you not use the brakes from the car the engine used to live in ? or are you wanting the ability to use 13in wheels?
2006 Audi A3 2003 Fusion 2 looking for a project....
this id like to see
Ace! Glad it runs Know of a near-mint BRG Sprint for sale, ~3k, also a Brian-Kitley built one for 3k ;D Kinda real money though
Well done mate, cant beat the feeling of hearing a car running that's been dormant for a while..
bstardchild
Club RR Member Number: 71
It breathes!bstardchild
@bstardchild
Club Retro Rides Member 71
Thats a stunning install - a friend of mine has installed one in a Capri and it's performance is stunning.
Smiler
Thanks for the encouragement guys.
The donor cars brakes are mounted on the inboard face of the hub where as the mk3 granny donor has outboard mounted discs and sliding callipers (as with all modern cars).
I have however retained the brakes from the donor though as they were lifted straight from the Sierra Cosworth!
I am using spaced mk2 Granny callipers with Capri 2.8i vented discs (when I find some) to give better cooling as brake fade is the only real problem with 'tina brakes. Also means she can keep her original alloys. Looking forward to upsetting a few new Audi owners on the dual carriage way!
When it's done I'll bring it to a few meets/shows.
Smiler.
Result! Looks like the makings of a great sleeper.
It breathes!DarrenW
@darrenw
Club Retro Rides Member 74
MMmmmmmmmmm... 24v Cortina. One of my daydream cars ;D
Superb stuff!
Stu
Excellent work! ;D
Smiler
Thanks guys. Didn't get to play with it much today due to a short lunch break but will hopefully sort the power to the coil pack etc.. tomorrow to make it more 'turn key' than 'hotwire'.
Then once the electrics are done it's off with the plenimb to fix the air leak.
