Sept 8, 2011 17:43:44 GMT
Hi everyone,
It's been awhile since I last posted! Anyway I am in the process of fitting some pug steel wheels to my audio 90. Have got spigot rings and centre caps and the wheels have been painted so they are ready to go on.
However there is a small issue in that the pug wheels have slightly smaller lug holes. They literally are only a mm or so smaller! Can get audi bolts through but only by winding it in. This is obviously going to damage the threads at best.
So how do I enlarge the holes? I did consider using a drill etc but largest drill bit is 12-13mm which is not large enough.
I could used a dremel etc but don't think that would be even enough!
Any help would be appreciated!
Cheers!
bl1300
Sept 8, 2011 19:24:02 GMT
Take them down to your local machine shop and ask them to drill them slightly larger. They wont charge you more than say £30 to do them all
Current fleet.
alx
Club RR Member Number: 21
Sept 8, 2011 19:55:17 GMT
Dez
Club RR Member Number: 34
Sept 8, 2011 20:02:10 GMT
why don't you just buy a drill big enough to do it?
Sept 8, 2011 21:05:29 GMT
i wouldnt use a step drill unless you've a drill press to use them in. Either pop down an engineering firm or buy the dril (again id recommend using a drill press though)
1994 Rover Metro 1994 Peugeot 405 Estate 1991 Rover Metro Gti 16v 2001 Fiat Seicento Sporting 1999 Fiat Punto 1.2 1994 Peugeot 106 Xnd (x3) 1991 Westfield 7 2004 Landrover 110 SW 2003 Seat Ibiza 1.9Tdi Sport 1959 Ford 107e Prefect 1992 Suzuki Vitara 2008 Skoda Fabia
Sept 9, 2011 10:04:43 GMT
Use a conical cutter rather than a stepped bit. It will self-centre on the original hole, where a stepped one will be hard to centre. I have a few of these and they are ideal for enlarging existing holes.....
Sept 9, 2011 10:34:03 GMT
Hi,
Thanks for the replies! They have been helpful, the main reason I didnt get a bigger drill bit is that none of the drills we have would have a large enough chuck so would need to buy a bigger chuck/drill which is a bit ott for one job.
I would take it to an engineering shop but I really don't have enough spare cash to do that.
However the conical cutter looks ideal, where would I get one of those? Are they expensive?
Thanks to everyone for the help so far.
Dez
Sept 9, 2011 10:46:50 GMT
you don't need to buy a bigger drill. no drill bit has a shank bigger than 13mm(that youll be able to buy anyway), thats why all drills you can buy only have a chuck that goes up to that size. you can get drill bits for a standard 13mm chuck that go up to about 22mm. a 14mm one (which I'm guessing is what you need) will be about £6-7 from machine mart.
markbognor
Club RR Member Number: 56
Sept 9, 2011 11:07:07 GMT
Sept 9, 2011 11:56:17 GMT
Ahem, oops I never knew that!
Feel a bit silly now, will go to machine mart tonight and get the drill!
Everyday is a school day!
Last Edit: Sept 9, 2011 11:57:11 GMT by trogdor
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Sept 9, 2011 12:29:00 GMT
Known in the trade as 'Blacksmiths drills' Very often tho, the next prblem is getting the drill to turn slow enough for the larger radius drill bit
