Sept 2, 2011 15:08:01 GMT
evening ladies, ive got my mk2 on the road, 2.8 ghia x, lovely to drive, but, its an auto and I'm already bored of its ooh i cant make my mind up going up hills jazz.
after everything id need 2 swap it over! pm's if anyone has anything kickin around
Sept 2, 2011 19:13:45 GMT
just a thort , why not bung a 24v cossy in front of the auto , will be more fun then
2005 e61 m'sport 1979 chevy c10
Sept 2, 2011 19:31:46 GMT
Wud more than consider an eng n box combo,but manual is the way forward I think!
Sept 2, 2011 19:43:42 GMT
ok mate will see what me mate's have lying around don't forget you will need spigot bearing as the auto dosnt have one, and spedo cable , don't wory about changing whole pedal box you can just remove the big brake pedal and fit the manual brake and clutch pedal ,the pipe should be in bulkhead to accept clutch cable , you will also need to bypass the park start switch wiring on aoto box
