hi there i have a 1 litre corsa reg s134 wbc . what happens is engine light comes on ( orange on dash ) . car struggles , i change down gear say from fith to forth , it clears eventually , i bang back onto fith and soo as owt light on again and its struggling
my question , could it be the maf , or egr if so how easy to change myself or is it a garage job .
i got quite a few tools and I'm somewhat handy , also which is the right sensors for my car ?
anyhelp would be great
many thanks
richard
eastwood notts
if you have helped me with advice or parts thank you so much ... should anyone require some dining chair covers gimme a shout. I make and manufacture them .
thats great , my light only comes on whilst driving does this matter ? and only at around 55 to 70 mph , then turns on and off once gear changed occurs and the issue explained previous . (if that makes sence )
guess I'm really asking , can i read a fault even though the light isnt on ?
thanks richard
If the light is on for more than 30 seconds, it's logged in the ECU. Be careful though, it will show a problem with either the crank/cam sensor because the engine isn't running. I kept ignoring this on mine and it turned out I had a problem with both
Sept 2, 2011 15:06:35 GMT
so I'm better off just swopping out maf and egr , covering both bases as it were
Sept 2, 2011 17:09:01 GMT
Probably the ERG sticking. Just had to bypass the ERG on my mates Astra. Coke can, scissors and 15mins and it was sorted
Sept 3, 2011 18:55:10 GMT
thanks . anyone know where the maf is ? so i can disconnect it please? again ive got a 12v 1.0 litre corsa
Sept 3, 2011 19:12:56 GMT
Look at the airbox, and follow the hose back to the engine. Part way along there, there will be a wire. That's the maf. It's similar to this.
Sept 3, 2011 19:14:50 GMT
Only swap out the MAF if that's the problem. It's an expensive part. Could be the Lambda sensor, doesn't sound like the usual ones.
Sept 3, 2011 19:47:57 GMT
thank you , will see tomorrow . all the best . if it is lambda , ive done a couple before on other cars , does the corsa have 2 ?
one near head and one on exhaust somewhere ?
are they both easy to get too ? ive done one on a ka, skoda , suzuki wagon , all very tight but managed it
Sept 3, 2011 20:50:31 GMT
To save a lot of grief you would be better off taking to a garage and coughing up to have the codes read. Most places charge between 30 and 40 notes, i do it for 25. Get them to print out the codes that are stored then clear them and see what ones come back. That way you will save a lot of time and money chasing faults that might have stored in the ecu for years.
R.S. Autotech. Servicing/Repairs/Diagnostics.
Sept 3, 2011 21:00:40 GMT
On that age Vauxhall, disconnecting the battery for 10 minutes clears the codes, and doesn't cost a penny.
Sept 3, 2011 21:13:15 GMT
On that age Vauxhall, disconnecting the battery for 10 minutes clears the codes, and doesn't cost a penny. and all youve done is exactly that cured nothing.just have it plugged in its £20 at my place or just change everything on the car ie every sensor and then when it still comes back on after a good few quid on mafs and egrs then go and have it plugged in guessing isnt the best route or if thats what we are doing i say its the near side rear wheel cylinder
97 volvo 940 turbo wagon 87 fiat strada abarth 78 gs1000 82 katana 1100 84 gsx1100 efe
Blimey its cheap up north. Not heard of a garage round here charging less than £35. Which personaly i think is disgusting for some apprentice to spend 5 minutes plugging in a solus.
`state
Yorkshire and The Humber
Why spend money on having it plugged into the magical machine when the paper clip test does the exact same thing? Ive being doing it on my vauxhalls for the last 15 years and its always spot on. Dissconect the battery for 10 mins so you loose any old fault codes it could have being storing.Then take it for a run so the eml comes on afew times.Then do the paperclip test.Put the clip in,then turn the ignition on.Count the flashes.See what the number comes up as on toppbuzz and your sorted.
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
Rob
Sept 4, 2011 10:01:01 GMT
paperclip test doesnt work on 1.0 corsas, and they only like certain scanners, usually the dearer ones. and on these its 1 hr to wipe the current codes from the ecu, but it doesnt clear history codes. best bet is as said get it read and cleared at a garage.
Sept 4, 2011 12:11:29 GMT
Also the 'paperclip test' will only access a very limited number of fault codes. It will tell you for example there's a fault with the maf but it won't tell you if its signal or supply, range/performance related. Fault codes only give you a clue to the fault and I like to have as many clues as possible before I start throwing money away.
Sept 5, 2011 10:00:06 GMT
i just disconnected the maf , and car runs fine , so ive brought a replacement , didnt wanna go scrappy for one as its a common fault with the corsa . so brought one from vaux world .
swop it out and see whats what , should be fine , thanks for all your help ill keeop you posted thanks
richard
