foxy99
Anyone restoring a classic XJ6/XJ12 will probably appreciate that there are good quality repair panels available for practically every part of the body (from dealers like Martin Robey/David Manners etc). I have purchased: inner & outer sills; sill end caps; rear wheel arch inners/outers; radius arm box section; front jacking points & front wing nose-cones. All but one panels have been from one of the many established dealers and are as true to the originals as you could expect. I was a bit miffed however that after spending weeks measuring and trimming then welding on the inner arch repair section that there was a gap of about 1cm between it and the lip on the outer panel when that is offered up. I've not thought of a solution yet so the job remains unfinished a year or so after the inner went on...... I have now moved to the other side of the car, where nothing has been touched, and made several comparisons and there is definitely a problem. When the rot is cut away and the new sections welded in you won't be able to spot/plug weld the lips together because of the gap. It seems to me that the outer panel would fit perfectly if it was welded on top of the old rusted bodywork but not if you cut the rot out. Anyone got any thoughts on this? LHS inner and outer arch repair sections. outer panel is more brown than black and this may make gap between lips more visibleRHS panels show same problem. outer panel here was bought years before the other three and has different labelling yet same gap existsprior to fitting gaps could be closed up with clamps. I assumed gap was deliberate in to allow for heat etc when panels welded ininner arch repair panel well shaped and blends in very well with original bodywork
Last Edit: Dec 9, 2011 2:42:16 GMT by foxy99
You're not the first to notice this! Lately they've been a bit poor, and several of the Jaguar forums have posters reporting the same issue. They appear to almost be a cover panel rather than a cut out and replace.
I've got one to do on my series 1, so I think I'm going to go for a full wing and inner, rather than repair.
Best of luck,
Rich
"You're about as likely to come across a fully functioning old Jag, as you are a taxicab that smells agreeable." - James May
To add to this... the last one I did used a repair cut to size from a genuine Jaguar full inner panel, which meant I could cut it to suit. The outer repair was a pressing by a German company and was first class in fit and shape.
foxy99
Sept 1, 2011 23:29:02 GMT
Thanks very much for the reply Rich. Its great to know I'm not imagining it!
I've held off from putting the outer panels on but the inner is on on one side and I'm very happy with the fit but was worried it was to 'short'.
The panels are not too expensive so I might buy another couple of the outers in the hope they are a better fit.
My panels were made in Denmark incidentally
Graham
Sept 4, 2011 10:39:48 GMT
If the new panel turns out to be the same, I would be tempted to flatten out the inner arch and reform the lip to suit the new outer arch, hopefully there will be enough material on it to do it without adding any metal, but if not you could always weld on a new inner lip in its entirety once the inner arch is cut to the right shape, as you would be doing this without the outer arch being fitted, it should be easy enough to make a good job
foxy99
Sept 4, 2011 16:42:04 GMT
Thanks for the suggestion Tony. This could work well as the inner won't be visible so better to adapt that than mess with the outer which will be on show The outer is quite generously made so there is a lot of it I won't need and, since I will be trimming a lot off the top of it, I can maybe push it up further to meet the inner. outer panel is bold enough to fit over original body at dog leg and wheelarch. cover panel? not all of original outer arch needs cut away at door so shape of repair panel here is not an issueinner arch repair panel trimmed and almost ready to weld in
Last Edit: Sept 6, 2011 2:15:25 GMT by foxy99
foxy99
Now that the inner is on I am making the best I can of the slightly outsize outer repair panel. Its still much better than having to form something from scratch. That must be a nightmare job! I've trimmed a lot of it away and clamped it loosely in place ready to start welding but you can see from the second shot there is a bit of a flange gap . Not the end of the world tho. There is also a bit of a problem at the front where, I think, I should have positioned the inner panel a couple of mm's further inboard outer panel trimmed and almost ready for welding in(brown) outer panel against (black) inner panel shows unfortunate gap between lips which are supposed to be close enough to spot weld togetherfront of outer panel sitting a little out of line as inner panel under it should have been positioned slightly further in
Last Edit: Sept 7, 2011 1:58:33 GMT by foxy99
foxy99
Last Edit: Dec 9, 2011 3:34:35 GMT by foxy99
robg2
Dec 14, 2011 21:50:11 GMT
Some good quality welding there...!
10mpg
Club RR Member Number: 204
Dec 15, 2011 18:25:27 GMT
I cant see the problem...?
The outer is visible so has to be welded on where it looks right, the inner isnt visible so just dress this back so it lines up with the outer, if you are any good at panel beating you'll never notice the panel has been altered..
Then just drill and plug weld them together or spot weld if you have the gear...
simples..
Jan 14, 2012 20:45:05 GMT
Whooooaa, looks like a nightmare! Glad I spotted this thread, I have to do some repairs to the back end of the arches on my '75 XJ12L, I bought an arch off ebay to cut up for the repairs, I wonder if its one of the 'cover' type.. Luckily I don't think I need to replace the entire arch, just the back corners, but we all know what happens when you start taking the paint off! Nice to see a VDP getting some love by the way.
71 Gilbern Invader II 72 Gilbern Invader II 71 Lancia Fulvia Cp 72 Lancia Fulvia Cp 76 Lancia Fulvia Cp 75 Jaguar XJ12L 77 Lancia Beta Coupe 87 VW T25TD Reimo 89 Alfa 75 T.Spark 89 Lancia Y10LXie 90 Lancia Delta HF Martini 91 Alfa 75 3.0 Clov 93 BMW 525iX 94 Ford Transit 95 Alfa 155 2.0SP 97 Alfa 164 3.0 Super 99 Alfa 156 V6 00 Peugeot 106 Sport 02 Audi A6 Avant 04 Alfa GTV jts 05 Citroen C4 2.0HDI 06 Alfa 156 V6
foxy99
Hi daddygiraffe. Sorry I didn't reply to your post back in January.
I only re-visited this thread today as it was time to slot the arch repairs into my main resto thread.
I get the feeling they might all be the cover type asI have bought 3 different ones and they are all much the same.
Not sure why this is the case unless it is somehow easier for the makers to produce then like this or perhaps the vogue with bodyshops at some time was to use them like they would use cover sills.
Who knows but I wish I had know about it before.
Any chance of some pics of your XJ12L?
foxy99
Apr 20, 2013 18:21:02 GMT
Last Edit: Apr 22, 2013 3:30:47 GMT by foxy99
