Though it would of been a good idea to steam the engine bay since the rocker cover gasket is leaking and I thought it would clean the engine bay up. Well it did, but at the expense of it running properly :oops:
if you listen to it at 1min 10sec when your cruising along it splutters. Its as if turning the ignition on and off or keep opening and shutting the throttle. Whats in the engine bay that can be damaged by steaming it? :B Already changed the spark plug leads and dizzy cap. The odd thing about it though, is when you floor it, it runs fine.
This will be my 5th car and the 1st one to have injection so I have no idea what to check or what doesn't like water.
www.facebook.com/v/257688117595080
Also after steaming it, it seems that my starter motor has started to seize. As when you come to start it, you have to turn the key a couple of times before the starter motor will actually spin. don't know if thats anything to do with it.
Any help will be greatly received
Many thanks
Ryan.
Many thanks
Ryan.
