stueyt
Saving cars from the scrapyard.
Aug 22, 2011 11:34:08 GMT
Remove the lock and take it to a locksmith, they should be able to cut you a new key from the lock. If they are worth their salt they can do this with the lock in situ. Don't use the high street key cutters because they won't be able to, or secondly call your insurance company and tell them what has happened, they should be able to help you.
Cheers,
Stu.
Last Edit: Aug 22, 2011 11:34:43 GMT by stueyt
Always looking for the next project!
bortaf
Aug 22, 2011 12:51:18 GMT
Lock number will be on the drivers lock or the boot lock, failing that a locksmith or DECENT car spares shop will cut you one from the lock, had the same problem on me lucida last year, cost me £35 to have 2 keys cut from the door lock Don't forget to tell whoever does it there's a bit of key in there so they can remove it (if that is you take the lock out with the key part in there ?
R.I.P photobucket
Sinky
Run Baby Run......Please!
Aug 23, 2011 14:09:29 GMT
Thanks . I found the broken piece.New keys cut.
2001 Volvo XC70 wagon
2003 Piaggio X9 Evo
