Hi all, need to get rid of a few bits.
First off, pair of post '84 rear drums (spacer type). These came off a 1998 mini, so there is NO lip at all on the braking surface. £10 for the pair?
Next is an MPI cooper steering wheel, coloumn and stalks/switches. It all works great, but the cream leather on the steering wheel is not 100% on the right hand side, but its perfectly useable. A bit of hide food may fix it, i'll get some close up pictures soon.£40 £30 posted
MPI full wiring loom, with fusebox and a few other little switches still attached. Cant tell you much about this, don't know much about MPI wiring, but its all there. So of the spade connectors on the rear section are a bit squashed, but its a good useable loom.£40 £25 posted (theres one on the 'bay for £80, but I need it gone).
MPI airbag wiring loom, great condition.£25 £15
Update;
Handbrake mechanism, single cable type. Looks literally brand new, even the rubber grip is excellent.£15 £10
Brake servo bracket, this is what the pedal connects to in the engine bay. Good as a replacement or if upgrading to servo on an older mini. £10
I also have an MPI pedal box, with clutch and brake pedal.£20 £15 posted
Collection from colchester, postage will be extra unless stated in price. Keep an eye on this thread, there may be more bits added. Tell me what you need, i'll have a look in my workshop and see if I can help you out
Update;
