hi
i have got a problem on my 1977 Granada 3.0 estate.
do anyone have a tip on where to get a hold of a new radiator with inbuilt oil cooler for the automatic transmission.
Jon
ford driver
rodit
For just a standard rad i use gat radiators in the midlands in the uk. May be able to do you one? If not try the likes of pace but that may be very costly?
Have you tried searching e bay?
Best of luck with your search.
Low and slow
Why can't i tune it?
Jul 28, 2006 10:15:34 GMT
good luck with finding an auto rad - they are as rare as you could always get a manual rad, and add an oil cooler
street
6.2 ft/lbs of talk
Jul 28, 2006 10:35:35 GMT
If you cant find one for the granny, maybe do as Autofive has suggested, or get a rad with a built in oil cooler from a Volvo or merc and adapt to fit? Or will you be able to get your rad reconditioned for a reasonable price?
Jul 28, 2006 10:55:27 GMT
to x-reference another thread, Do Scimitars use this rad?, few of them breaking on ebay
Last Edit: Jul 28, 2006 10:56:02 GMT by Autofive
radiator problemBenzBoy
@benzboy
Club Retro Rides Member 7
Jul 28, 2006 13:14:23 GMT
I know that W126 Mercs have a built in oilcooler for the tranny. Like street said you could perhaps make that fit. I made one fit my W115 Merc by using different radiator hoses with the correct bends in, and a steel cross-over pipe from a Metro (the inlet / outlet ports were on the wrong side on the new rad)
Do your local car parts suppliers have a radiator exchange service? In the UK you can order a rebuilt radiator in exchange for your old one. Or if there's not one in stock, they'll rebuild yours for you. Serck Marston are a company that do this in the UK. It isn't cheap, but you'll have a shiny rebuilt radiator at the end of it!
Jul 28, 2006 14:02:46 GMT
I know that W126 Mercs have a built in oilcooler for the tranny. Like street said you could perhaps make that fit. as do w123s.
Jul 29, 2006 16:32:46 GMT
Jul 29, 2006 19:56:04 GMT
mk3 capri rad is the same as granada, except the header tank pipe outlet is on the other side. I have a granada auto rad in my capri. mine has an external trans cooler plumbed in, but auto rads have a larger header tank. you can get your one rebuilt, unless it has split the trans cooler. hope that helps
