Aug 15, 2011 13:14:08 GMT
help ive got quad down draft carbs on a roverv8 and i need to have a choke of some sort but i cant find any outlet as it needs to operate all the carbs as in quad but all choke sets ive seen are for twin set ups.
anyone know or have a quad choke set up on there motor to show me what i need to use please.
i done have a lot of space to play with any help would be of great thanks.
Aug 15, 2011 13:39:51 GMT
You are a legend for having quad carbs on a V8! I think you might struggle to find a choke setup for them though, I imagine that most quad-carb setups would be on race engines and therefore don't need chokes. Good luck!
Aug 15, 2011 15:26:56 GMT
a legend am i, thanks for that..... the engine is race spec but used on the road, well it was when it was m.o.t'd the frist and last time i used it. looks i might have to make somthing up, hopefully someone else might have been in the same boat and done just that fingers crossed.
Aug 15, 2011 19:03:09 GMT
never need a choke on a downdraught or a side draught.
why do you think you need a choke? does it cough, splutter loads when cold? a few minutes warming up is usually all that is needed.
are the carbs balanced/set up properly?
Aug 15, 2011 19:09:11 GMT
As far as i know i did pay to have the carbs set up, but it coughs and runs like a pig when cold at one point i did have one choke cabled up and it did make some improvement when cold, i was advised to get them working thats what made me look into it.
so its really a choice thing 'to have or have not' choke wise i mean.
Aug 15, 2011 19:18:38 GMT
so it's fine when hot?
it may just be a little to lean at progression. also ignition timing could have a profound effect. it may be set up for full power but what is the timing like at low rpm?
being a V8 and large cams you can get away with a lot more bottom end advance to make the engine a bit perkier. problem with quad carbs is you can't have a vacuum advance so more low end static advance is the only way.
Aug 26, 2011 20:23:14 GMT
so did this get sorted? it'll be easier to make the engine run slightly richer at the low end and not need a choke. float height really affects the low end mixture. i still don't think you need a choke. and if you think i'm talking curse word i do this sort of thing for a living and before you ask, no it isn't a kit car
