Anyone know of a uk supplier? I'm thinking of going to 7or8x13" wheels on the back of the standard and 6 on the front, however I won't be able to have them banded unless I get the centres moved or a bit added to the front and back. Only ones I can get at the moment are 15" in widths from 8-14" for £45-£75. Some off road places in the US do them so i know they exist over the pond. If I could get some shells I could just tack them where I want and get them welded in fully by a pro. Have a picture:
1977 datsun 810 180b estate
Aug 14, 2011 10:20:05 GMT
The issue is with the steering arm on the front as rear axle will be getting chopped to fit the car and offset anyway. As an alternative, I could keep these and run 15"s 6 wide on the front 8 wide on the rear (2 inch band to outer edge). thoughts please
Last Edit: Aug 14, 2011 10:22:53 GMT by damien4884
don't know anyone that sells just the rims over here at all?
maybe just get some wide steels that a re the right size and rit your wheel centres into them?? something like a 80's fast ford or vauxhall would probably have 7x13" steels i would guess..... or wellers?
Current fleet: '58 A35 (half mine) '67 11 window splitscreen vw (half mine) '77 mini 1000 (not quite 1000 any more!!) '86 Armstrong MT500 '89 XR4X4 '94 Corrado VR6 Some sort of sevenesque kit car (no age yet!!) '01 Mondeo estate 2.0 (engine eventually destined for kit car!) - scrapped, engine only left! '98 E300 estate, rusty but seemingly reliable, fast-ish tat hauler. eventual engine donor A35 van, or whats left of it after it lived in a field for many years
mk2cossie
Club RR Member Number: 77
Steel wheel shellsmk2cossie
@mk2cossie
Club Retro Rides Member 77
Aug 16, 2011 20:40:03 GMT
hmm, I'm liking the look of that 15 in the front arch ;D with just the right profile tyre to give it a square looking sidewall ive heard that in Australia you can buy the outer sections to get bigger diameter and wider steels with your original centres, as banding is illegal out there
Aug 17, 2011 13:53:36 GMT
Theres a lot of places that sell them abroad, I can get 15" in 8-14" wide over here from speedway motors for a decent enough price.
The other issue I didn't think about is that not all wheel shells are made the same, so there is some variation in the size of wheel centres. it looks like i'll keep the 15"'s and get the rears banded 2" when i can afford it.
Last Edit: Aug 17, 2011 13:54:18 GMT by damien4884
Oct 14, 2011 21:43:32 GMT
Hello did you get something sorted ,iam trying something similar and having the same problems using mondeo 15x6 with 4x108 pcd , i reversed the centers so i wouldn t have to use a 25mm spacer on the front (its mk1 cortina) but then its very very close to rubbing onto the wing once tyres fitted. Theres not enough width to the raised section on the rim (inner diameter) to weld back the center onto and get the offset i am looking for---its pushed to the very edge now and idealy i would want to try for some more offset towards the strut.As i now have 25mm clearence there.No issues on the rear and i want to split two rims then weld up back to back to make a 15x9 rim on the back. cheers
mk2cossie
@mk2cossie
Oct 14, 2011 21:58:34 GMT
if the only trouble at the front rubbing the wing (presuming you mean the wheelarch section), can you not just give the wings a gentle tug out a bit for clearance?
The wheel shells in first post are about £45 for a 8", maximum back space on a 8" rim is 6" (based on a flat centre) I don't know if 2" from hub would be better than what your currently at? Alternatively its finding some wheels with centres like these: On those the mounting face is 15mm forward of the welded flange, also the flage sticks out 5mm front the center of rim, which could possibly give you more movement, however they look a bit pants as the centre sticks out past the rim a fair bit. You do get an et of 49 on a 5 1/2" rim though I've solved my issues by running the 15's Got a manta axle and front hubs to collect then i'll fit the hubs on with either suitable bearings or make another pair of stubs to do the job. Other option is as mk2cossie suggests
