Aug 13, 2011 21:46:14 GMT
Well I have a Polo bread-van used for local round the doors, I was going to convert it to electric but then got to thinking if Propane is good for forklifts it will do my Polo.
So help me out here chaps what do you know???
Christoff ? Anybody...............
Aug 13, 2011 22:42:26 GMT
It's called an LPG conversion It's just a propane/Butane mixture, similar to camping gas
In my personal opinion, LPG conversions are okay, but really they work best on large cars which do high mileage. For a small car running locally I wouldn't bother at all. The reason for this is because most LPG conversions cost you a huge amount of luggage space which is taken up by the gas cylinder, and most of them tend to cost the engine some power, especially if it's set up to run dual-fuel (switchable petrol/LPG).
The cheapest type of conversion is the traditional carby-type mixer. These cause hard starting (long cranking time) on LPG and it's usually advisable to start the engine on petrol and switch to LPG. LPG is hard on engines because it doesn't offer any of the lubricating or cooling properties of liquid fuels, meaning that your valve guides will wear and your valves will run a lot hotter. LPG conversions tend to use at least 30% more fuel per km but the fuel is usually much cheaper so this compensates. However, in a small car which is probably already doing very good fuel economy, the savings will be miniscule. With only short local trips, it will take many years to break even on even the cheapest conversion. Even if you got the conversion for free, with a car like a Polo I wouldn't sacrifice the boot space and power for the minute savings in fuel costs.
Good points wave-man cheers.
Aug 14, 2011 15:56:59 GMT
I dunno about 30% more... But yeah, more fuel is used. But the fuel is substantially cheaper.
Carb conversions are less efficient than EFI but an injected conversion is more complex and will cost more to convert.
I ran my old Cadillac on LpG and no difference in performance on gas or petrol and I still beat the "factory" fuel economy figures when running on LPG. That was an EFI motor though
As said the margins are much more attractive on a large car but if you can convert it cheap enough I reckon it could be the win. You need to do your sums really
Dez
Club RR Member Number: 34
Aug 14, 2011 23:10:09 GMT
i don't really think its worth doing on anything under about 2 letre. a mentioned the savings just arent big enough to offset the installation costs, even if youre DIYing it. youd loose all your luggage space fitting a kit to a polo too.
and most basic single point mixer-plate type systems (the type youd need to fit to a carbed polo) will use a lot more than 30% extra- more like 50-60% depending on temperature and type of journey. but the fuel is half the price, so its still a substantial saving in a larger car though. I'm my 3L senator, it was making a £20 journey cost £15, doing that 3 or 4 times a week and you certainly appreciated it. but saving 2 quid on a £10 journey isnt going to be as noticable.
stefan
If it isn't broken fix it till it is
I have had lots of cars on LPG and they averaged 5% more fuel on LPG than petrol, thats both with mixers and injection, the smallest was 2.4l and the biggest was 7.2l I love the stuff.
For DIY conversions have a look a tinlytec web site they are the cheepest I have found
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
my 1.3 hijet uses pretty much exactly the same amount of lpg as it does petrol so very little loss in efficiency. Its just a single point basic system.
Last Edit: Aug 15, 2011 9:20:53 GMT by 8bitash
1970 Porsche 911E 2002 Porsche Boxster S 2002 Peugeot Partner 1.9sdi
bortaf
Aug 15, 2011 12:59:25 GMT
I don't really think its worth doing on anything under about 2 letre. a mentioned the savings just arent big enough to offset the installation costs, even if youre DIYing it. youd loose all your luggage space fitting a kit to a polo too. and most basic single point mixer-plate type systems (the type youd need to fit to a carbed polo) will use a lot more than 30% extra- more like 50-60% depending on temperature and type of journey. but the fuel is half the price, so its still a substantial saving in a larger car though. I'm my 3L senator, it was making a £20 journey cost £15, doing that 3 or 4 times a week and you certainly appreciated it. but saving 2 quid on a £10 journey isnt going to be as noticable. 50-60% your having a laugh surely, even a 1.3 Mk2 fiesta I service only looses 20% that's on a curse word mixer plate under the carb and the system was fitted new so it's a very basic old, OLD setup with no timing advance when on gas, it'd be even less if he changed to a switchable ign modual.
Last Edit: Aug 15, 2011 13:00:41 GMT by bortaf
R.I.P photobucket
If you are worried about luggage space then use a donut tank in place of the spare wheel, carry a can of tyreweld.
Aug 18, 2011 12:39:58 GMT
some curse word been talked in this thread. ive lpg'g my 325 e30, cost me about £200using second hand stuff and cheap bouht bits and £120 of that was buying a new wide band lc-1 to help with setup and tuning, got a donut tank in the boot, still got plenty of boot space.
mines a open loop basic system, which returns about 20mpg, which is pretty much the same as it gets on petrol, power loss is minimal, noticeable but not massive. if its setup right youll be well happy and nearly half ur fuel costs.
Onne
Aug 19, 2011 14:38:43 GMT
I run my 3 litre Merc on the stuff, does 21MPG on petrol, 18 on gas. So no complaints here!
1990 Mercedes W126 300SE 1997 Mercedes W140 S320L
Aug 20, 2011 21:02:26 GMT
I was going to convert it to electric but then got to thinking if Propane is good for forklifts it will do my Polo.. Running a bottle from a forklift will work fine as they're just LPG but is naughty to do because the road duty isn't paid and most basic single point mixer-plate type systems (the type youd need to fit to a carbed polo) will use a lot more than 30% extra- more like 50-60% Thats curse word, from experiance if its using any more than 15-20% extra the conversion is either spec'd wrong or incrediably badly set up. I doubt that you would notice the power loss either to be honest. Over a lot of years we've managed to get a carbied Rangie to do more mpg on LPG than on petrol with a lot of messing with ignition timing different plugs etc, thats running a basic open loop but well spec'd kit originally fitted back in 1988....
Aug 21, 2011 19:43:45 GMT
What ^ he said!
I did a 4.6 rangy that managed 17 on gas with a basic variable piston mixer setup.
Koos
Aug 21, 2011 19:45:24 GMT
Oh if you are naughty and run off gas cylinders remember to turn them upside down as you want liquid not vapour.
Not that I'd condone avoiding being shafted for fuel duty or anything.
Koos
icedmunkie
All smoke.... No poke
Aug 25, 2011 12:20:36 GMT
Used tinley techs stuff on a landy before, good kit, happy with it
1972 Vauxhall Firenza 1.8 MX5 powered 19something Land Rover Series 2 (in bits and not started)
Aug 29, 2011 20:06:01 GMT
Oh if you are naughty and run off gas cylinders remember to turn them upside down as you want liquid not vapour. Not that I'd condone avoiding being shafted for fuel duty or anything. Forklift bottles have a liquid take off.....
Sept 1, 2011 21:09:12 GMT
But camping gas bottles don't ;-)
Koos
bortaf
Sept 1, 2011 21:47:46 GMT
or you could just invert a camping bottle and pump it into your tank on the car, either by hand pump or leccy pump they are on ebay,,, apparently not that i condone it at all i just heard is all
R.I.P photobucket
Sept 2, 2011 21:15:17 GMT
If you are pumping from a bottle for off road or marine use then you need to have it at a slight angle to avoid getting the 'heavy ends' (curse word basically) into your system, the videos from the US of just connecting up a bottle to the filler don't work.... Some of the pumps on ebay are well dodgy, fancy pumping with an AC compressor spun by a washing machine motor?
