racer86
'72 BMW 2002 / '72 Alpine A110 Gordini
Jul 26, 2006 20:43:14 GMT
I have recently stuffed a 4k in my KP; The thing is the OEM Aisan carb has a connection to what i am assuming is the idle jet, which operates a solenoid. When given 12 volts the engine idles and rev sweet but when not connected it is pig rough and wont idle. Pic of carb in question Ive currently connected it to the ignition switch so its on when the engine is running is this correct? What is the solenoid for? is it an anti run-on system? Thanks for any help you can give me.
Last Edit: Jul 26, 2006 20:44:04 GMT by racer86
Snoozin
Toyophile
Jul 26, 2006 20:54:26 GMT
Anti-dieseling solenoid like you said It should be on when the igntion is on, basically stops run on when you turn the engine off, or when you back right off the throttle.
Nathan
Club RR Member Number: 1
Carbumaretta Technical QuestionNathan
@bgtmidget7476
Club Retro Rides Member 1
Jul 26, 2006 20:59:16 GMT
As above, I have the same thing on the MG but is Seperate to the Carb It Sits on theoverflow on mine. Keep it connected
Snoozin
Toyophile
Jul 26, 2006 21:00:34 GMT
Although if it's disconnected and you pull the choke out for idle it sounds like you've got the wildest cam in there..... get mean backfires on overrun too (I only know this because I forgot to reconnect it the first time I had the intake manifold and carb off).
racer86
Jul 26, 2006 21:23:45 GMT
Fantastic, cheers guys!
Jul 26, 2006 22:42:03 GMT
I have recently stuffed a 4k in my KP; Just a casual engine change, like.
Snoozin
Toyophile
Jul 26, 2006 22:44:54 GMT
I have recently stuffed a 4k in my KP; Just a casual engine change, like. It literally is... Undo about 6 bolts, and unplug and remove hoses. Engine and box drops out. Can do the swap in a couple of hours.
racer86
I spent about a day and a half, as everything had to be stripped, cleaned and painted. I had to change a number of parts aswell. But if the engine was ready to go in, its an afternoons work!
