Hello, i am having trouble with a friends VW T3 van, the lock mechanism is stuck/ broken inside and so the door can't be opened. I have removed the exterior handle (cut off as he has a new one ready for it) and it seems that the mechansim is falling apart inside.
So what can i do? I cant remove anything unless the door is open as you need the door open to remove everything...or unless i cut a hole in the door? Vans being resprayed and i weld so thats not totally out of the question...
If anybody could give me some advice as to what can be done, that would be great!
