kevfromwales
the conrod's REALLY out the block now!
Aug 12, 2011 11:26:23 GMT
hi guys
well it's almost the weekend before the gathering, and a state of mild panic exists at kev towers ;D - who said as usual!?
I'm trying to assemble the wheels for the bluebird - 14" 3 piece splitrim compomotives - the fronts have got their bolts all present and correct, but the rears have no bolts - so I went to the local engineering shop this morning, and got some nice high tensile allen head bolts
unfortunately, the original compomotive bolts have a shank (? - the non threaded bit!) where it passes through the wheel - and my new bolts are threaded all the way up - now I'd have thought that once it's all built up and tight, there's no movement, so there shouldn't be an issue - but with these being, er, wheels - I'd appreciate some input before I cause a bluebird shaped dent in a bus queue full of nuns
- I think I have enough scabby genuine bolts to get by - but I'd be interested if there's any actual reason not to use the new bolts?
cheers - kfw
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Aug 12, 2011 11:34:31 GMT
Assuming they are correctly torqued up, I can't see why it'd be an issue. The only thing I can think of is that the originals may have been like that to prevent the risk of damaging around the bolt holes on assembly. I'm only working on the same logic as you, so I'd want more confirmation first ;D
Aug 12, 2011 12:17:32 GMT
They will be fine. I ran a set of splits on one of my old racecars with full thread capheads and nothing ever fell off. Have you got the alloy cup washers to use on the front face?
muttley racing ftmfwmf
kevfromwales
Aug 12, 2011 12:23:49 GMT
yep - got the alloy cup washers, and got new flat washers and nylocs for the back
at least that's one thing I can sort then!
kevfromwales
Aug 12, 2011 19:06:22 GMT
thought I was going to have an even more serious issue - just went to put one of the splits on the back, and the centre isn't 4x114.3 - it's 4x108!!
after trying 2 other centres, I found that the rest of my job lot are 114.3 - phew!
so if anyone wants 3 14" comp split centres, or has an odd TF that they want to sell....
Aug 12, 2011 19:22:04 GMT
They sell complete sets on ebay for BBS wheels or if you contact schmidt (sp) they do them off the shelf in aray of colours to boot again pricey but I was looking at gold bolts for my Enkei splits, but by the time I worked out bolt prices it worked more than the price I paid for the wheels
kevfromwales
Aug 12, 2011 19:34:04 GMT
^^ cheers for that - but no time to wait for ebay - last minute pre gathering kfw chaos as usual!!
Davenger
It's only metal
Club RR Member Number: 140
splitrim bolt issuesDavenger
@dminifreak
Club Retro Rides Member 140
Aug 14, 2011 18:42:51 GMT
Why not alternate the bolts on each wheel? i.e. on with a shank, then one without, then one with etc. Would that put your mind more at ease?
