Aug 11, 2011 10:24:42 GMT
stuey
ram thruster 4000
Aug 11, 2011 10:27:07 GMT
I just drive mine onto a piece of wood so its high enough to get a jack under.
1987 fiat 126-nearly actually done! 1972 beetle - lawn art 2003 z4 daily-new wheels a comin! 2008 R56 Mini cooper "mental Mickey"
Copey
Aug 11, 2011 10:27:32 GMT
my capri isnt mega low and it wont go up them, so probably have problems
Aug 11, 2011 10:34:14 GMT
have you seen the lay flat ramps at all? considerably more expensive than those, but basically you drive onto them (when they're flat) then essentially jack them up.....
ill see if i can find some.....
Current fleet: '58 A35 (half mine) '67 11 window splitscreen vw (half mine) '77 mini 1000 (not quite 1000 any more!!) '86 Armstrong MT500 '89 XR4X4 '94 Corrado VR6 Some sort of sevenesque kit car (no age yet!!) '01 Mondeo estate 2.0 (engine eventually destined for kit car!) - scrapped, engine only left! '98 E300 estate, rusty but seemingly reliable, fast-ish tat hauler. eventual engine donor A35 van, or whats left of it after it lived in a field for many years
Aug 11, 2011 10:37:12 GMT
It all depends on how low your car is and how long the overhangs are. I'd need bloody long extensions to get my MX5 on them and you'd be surprised how many 'stock' height cars foul these ramps, let alone lowered ones. Slammed cars...forget it. Long extensions would need to be made, and if that is the case, you may as well maje some ramps from scratch
Aug 11, 2011 10:45:39 GMT
Dez
Club RR Member Number: 34
ramps and lowered carsDez
@dez
Club Retro Rides Member 34
Aug 11, 2011 10:50:29 GMT
i find its pretty hard to beat sections of scaffolding plank/railway sleeper cut at an angle and screwed on top of each other to make 'steps' to drive up. up one or two steps to get to the sump nut but keep it reasonably level, up a few more if you need proper access.
Lawsy
Aug 11, 2011 11:07:22 GMT
I've a set of them ramps and are useless for prettu much everything except the 4x4 - event he LS400 as stock height couldnt get up them without fouling
I ended up making some gentle slopes for them which were about the length of the car..
Still think you can beat a few blocks of wood screwed together and graded to give a nice gentle slope up
Aug 11, 2011 14:44:02 GMT
PPC was the mag haven't got it on me at the mo tho so can't tell you the make.
Gem
East Midlands
Aug 11, 2011 14:58:20 GMT
I have to drive up wood to get mine on the ramps.. then to get it off, I have to jack it up as it's mega low haha
Aug 11, 2011 15:31:04 GMT
i use ramps and 2 scaffold planks that are about 75cm long, never had a problem gettin anything up them
Aug 11, 2011 16:25:16 GMT
PPC was the mag haven't got it on me at the mo tho so can't tell you the make. bingo!! well done that man..... ive got it at home, ill dig it out when i get a min!!
thebaron
Over the river, heading out of town
Aug 11, 2011 21:28:58 GMT
Improvised and very, very cheap
Aug 12, 2011 10:24:22 GMT
^warning breeze block content!
in other news, depends where the clearance issues are, I have to take the front valance off of my cav to drive it onto ramps but it was no hardship once I spot drilled the welds and made it bolt on...
- '80 Mk1 Vauxhall Cavalier Saloon, 3.0l 12v... in progress with some special plans ahead - '94 106 Rallye, Endurance Rally Car
Aug 12, 2011 10:29:02 GMT
Man that looks iffy. Weight is acting to push back the blocks. Everything's on the corner/edge only. At least they should be under the wheel, not behind it. Those stands look weedy and aren't far back enough. OK maybe there's a jack or other backup system underneath, but still, could be better.
