Aug 10, 2011 13:34:39 GMT
hi guys another querie as I'm goign through everything on the corsair, it has had all new track rod ends put on it about 4-5 years ago and number 1 they are obviously stiff what spray grease could i use to lubricate and also grease them up as i thought using normal grease wont get 'into' the whole ball bit unseen to us..if that makes sense?!? what is the best spray grease to use then on the track rod ends and stuff like that? many thanks in advance
Aug 10, 2011 15:28:48 GMT
I'd just pack the rubber boot with a little normal grease as movement should then lubricate the "unseen" aspect over time. Some TRE's, such as the Minor, had a grease nipple or a blanking plug. Is there anything like that on the Corsair items ?
Paul H
Aug 10, 2011 15:37:54 GMT
as above, just use normal grease.
spray grease isn't intended for high load items like balljoints, I doubt the aerosol can generate enough pressure to inject the grease if the3y are equipped with a grease nipple.
don't forget that most balljoints if sealed will be extremely stiff if they are unused.
Aug 10, 2011 16:53:03 GMT
hmm looks like i will have to trust niormal grease then, and nah the corsair doesnt have any nipple or plug mate. they are not stiff at all just need a quick overhall before i use it daily, thanks for the help chaps
