Jul 25, 2006 15:34:22 GMT
Can anyone tell me how to remove car doors? as ive never done one before.. i know there held on by pin things, but how exactly do they work? if its just a case of bashing it out, which direction dose it go? Ive found a good clean door for my micra, but i need to remove it! any help, haynes scans etc appreciated!!!
2006 Audi A3 2003 Fusion 2 looking for a project....
Bioshock
It aint hip to be square.
Jul 25, 2006 16:14:40 GMT
Almera GTI = ugly bird who turns out to be great in the sack = Win
Jul 25, 2006 16:43:55 GMT
Usually there's a pin driven through the hinge with a circlip round the bottom. One end should be flared to stop it going all the way through, so you should be able to determine which direction to hit it in. Remove circlip, screwdriver, hammer, drift it out. Not done one on a Micra before though, so possibly they have a different set-up
Jul 25, 2006 17:17:45 GMT
the best way to remove a micra door is to open it just before a truck goes past. ;D it will be like BB says, or you could be lucky and the hinge might bolt on?
street
6.2 ft/lbs of talk
Jul 25, 2006 18:19:00 GMT
Yep as above, the hinge should be bolt on either at the door end or on the A pillar, a lot of them are. If its a case of removing the pin, its a bit of a PITA but not too bad. Take some WD40 and a selection of drifts/old screwdrivers to the breakers HOT TIP!- Its really obvious, but I always find myself doing it: remember to disconect any electrics that go to the door before taking off, aswell as the safety catch. I always found myself holding a door that was still attatched by the central locking/electric windows wiring! But that may be just a 'me' thing!
Jul 25, 2006 18:23:23 GMT
give me a shout when you want to get it fella ill bring my grinder
Jul 26, 2006 15:34:33 GMT
the best way to remove a micra door is to open it just before a truck goes past. ;D it will be like BB says, or you could be lucky and the hinge might bolt on? i knew it wouldnt take long for this suggestion lol cheers for all the info guys, hopefully off to get it tomorow, am hoping they will take the micra down carefully for me too! I'm hoping the new door will have central locking allready so o don't have to remove mine from my current door, altho the interior trim is different too... just had a poke about mine and look: (excuse the muck, aint cleaned it in a month!!!) bolts!!!! so whats this clip thingy? and how dose it work??
