I need to replace the rear discs and pads on my Mk3 Golf GTI. Can anyone recommend the best tool / method to wind back the caliper pistons? If I recall, some Mk2 Golf GTI calipers could be done with a big Allen key, but the calipers on mine have a different piston with two cut-outs near the edges. I've seen various tools on eBay but I thought I'd ask here in case any of you guys had any recommendations or tips.
Every car I've had to do brakes on I've loosened the bleed nipple and taken the cap off the cylinder bottle and either just used my hands or for really tough ones, a G-clamp.
Last Edit: Aug 6, 2011 18:36:19 GMT by MiniDan
If your not planning on doing it often one of these types will do the job for about a £5er
1977 datsun 810 180b estate
g-clamp
Thanks fellas. I did think about using a G-clamp but I'm not sure if the thread on the pistons are left- or right-handed. Plus if there's a chance it'll damage the caliper I might as well get a proper tool.
Dez
Club RR Member Number: 34
for golo ones with the notches in the edge of the piston, ive always just used a bit of flat plate that slots in the holes thats cut to length. if they don't easily wind by hand with that they're borked anyway..
grahamj
Old enough to know better....
cant remember if mk3 rears are same as mk4? , if so be careful as brake pipe goes metal to vw brittle plastic, it is easy broken when you remove from carrier... its bin done in my garage before !... and its a vw only part...
2005 VW T5 Dayvan 1997 VW T4 Dayvan Vauxhall Nova 2 Litre Redtop 1970 Moggy Van.. 94 vw Passat Bus 1985 Vauxhall Nova Base show car 1987 Vauxhall Nova 1.4 16v XE Rallycar
prey
bit of bar welded across an old socket!
30psi
On my old S12, I wound the caliper back in using the locking tool from an angle grinder
1962 Ford Thunderbird 6.4L
1981 Datsun Bluebird SSS CA18DET
1981 Datsun Bluebird SSS SR20DE
Indeed, G clamps muck up up the threads within the caliper on rear items (most have the handbrake mechanism built within the caliper). Like most I use a caliper rewinding tool, and for the fronts I push them in with an old pad using the tool. I could use a G Clamp but it does seem easier with the tool and old pad. As other have said, a crowbar's ends or pliers can also do the job, it depends on how much fiddliness you can put up with (this depends very much on the condition of the calipers IME and how badly the pads are worn.). Are you in Leicester ever? If so, if you could meet up halfway I could loan you mine .
Last Edit: Aug 7, 2011 18:04:43 GMT by ChasR
Aug 13, 2011 20:44:33 GMT
I forgot to update this. Thanks for all the advice, and Chas, thanks for the offer mate! In the end I went and bought a caliper wind-back tool set. Not that expensive and will come in handy (I like buying tools! ;D) Not used it yet, but tomorrow I will be. Let's hope the calipers aren't sh*gged!
I used a pair of pliers for the ones on the MR2! If they aren't seized up and you remove the reservoir lid it should be reasonable easy.
golf calipers are near identical to my 405, just a large screwdriver did the trick. its all i ever use even though i do have a wind back tool!
the tools hardly fit most calipers anyway :/
Aug 14, 2011 20:40:54 GMT
Well, I used the wind-back tool today and I have to say, it made the job really nice and easy! I'd be worried about stabbing the dust seal by using a screwdriver but other people may be less clumsy! ;D
paul4be
'86 Capri Laser, Frontera 4x4
Aug 14, 2011 20:49:28 GMT
Halfords do a wind back tool if you want one off the shelf. I've used a big pair of needle nose pliers in the past.
both the methods i use have been mentioned in this thread.... thin nosed pliers and a (modified!) pin spanner (normally used for locking angle grinders!)
I probably should buy the propper tool, but to be honest, they always wind back easy enough with one of the above....
Current fleet: '58 A35 (half mine) '67 11 window splitscreen vw (half mine) '77 mini 1000 (not quite 1000 any more!!) '86 Armstrong MT500 '89 XR4X4 '94 Corrado VR6 Some sort of sevenesque kit car (no age yet!!) '01 Mondeo estate 2.0 (engine eventually destined for kit car!) - scrapped, engine only left! '98 E300 estate, rusty but seemingly reliable, fast-ish tat hauler. eventual engine donor A35 van, or whats left of it after it lived in a field for many years
