hatsu
Will a 175/60R14 tire fit on a 7" rim? Was wondering what the max amount of stretch is safe and possible. Any one got any ideas on this?
Got the rims off my old 180bSSS and want to fit them on my 120y but the 195/60R14 on the front are just a bit to close to the body, it is slightly lowered.
craig1010cc
Club RR Member Number: 35
175/60R14 on a 7" Rim?craig1010cc
@craig1010cc
Club Retro Rides Member 35
That'll be fine, minis oftenly run a 175 (50) on 7x13's I ran a 185/6014 on a 14x9, which was quite a stretch
hatsu
Just found this site but its not got what I am after - www.tyrestretch.com/Am off in a bit to the tire emporium soon, so will post my result later.
Last Edit: Aug 6, 2011 10:49:55 GMT by hatsu
iv'e got 195's on my Coupe. stretch tyres look curse word imo i cut and reshaped the front part of the wheel arch (i assume it's just the front) when i get it out of the garage i'll take a better side view picture. once the paint is matched it'll look perfectly normal and not notice that it's been modified
hatsu
not really stretch then. doesn't look too bad at all. are you sure they are 7 inch? measurement is the inside of the wheel rims. have to get the cars side by side sometime
hatsu
Definatly 7" just pondering on putting 175 on the rear now to. Will leave it as is for now. Yes be good to get ours cars together, are you coming to the gathering?
kevfromwales
the conrod's REALLY out the block now!
here's a 185/60/14 on an almost 10x14 ( 9 3/4j took a far bit of work to fit, and it's not one for the sretch haterz -but got to be done for the authentic bosozoku style -just got to get some 195's on the 10.5j's for the back....
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
