fha772
Jul 28, 2011 22:39:09 GMT
Hi all,
I just wondered if anyone here has removed a coil from a lowering spring on a Mercedes W123? I'm just wondering how much lower this would make the car, seeing as I'm removing between 300-500kgs from the car, which is cancelling the effect of the lowering springs.
Has anyone cut 2 coils from a lowering spring? How much would that drop it?
Cheers Frank.
Jul 29, 2011 18:35:01 GMT
i had some 3 inch lowered springs made for the front of my 123. i had to cut a coil/ some coils off them to get it where i wanted it. unfortunately i cant remember how many i cut off as it was 5 years ago, blimey. anyhoo, heres how it sat last time it got an outing, which was a couple of years ago now. its just sitting in my garage waiting for its recommisioning. this shot is how it was when i get it. hope that is of some help.
fha772
Jul 29, 2011 19:10:39 GMT
Thanks, that has helped me a bit, that is about how low I'm planning, to keep the centre of gravity as low as possible.
Did you lock wire the springs in place?
markbognor
Club RR Member Number: 56
Jul 29, 2011 19:51:38 GMT
I had a coil off (I think) -40 lowering springs on my old coupe.
Jul 29, 2011 20:28:20 GMT
Did you lock wire the springs in place? no i didnt, as the springs don't dislocate when jacked up. also i wasnt planning on ragging it anywhere, using it more as a big comfy cruiser. lmao at mark, also not remembering how much he cut off.
