Jul 25, 2011 17:15:57 GMT
HI guys, Just a quick question, I'm sure its been cover a billion times before. Will I be ok fitting 4x100 wheels to some 4x4 hubs or will i need wobble bolts? Many thanks, Gareth Pics for gratitude
Jul 25, 2011 17:44:05 GMT
Unless the stud holes are a bit worn, you will almost certainly need wobbles. if the wheels you are fitting have tapered seats for the bolts, then yes, without doubt.
Err on the side of caution in this regard.
RobinJI
Jul 25, 2011 17:46:16 GMT
I've heard of it done loads with wobble bolts, but usually 4x4" wheels onto 4x100 hubs. I wouldn't want to try it without wobble bolts, there's a 1.6mm difference, which is enough to stress the bolts rather a lot.
Only trouble I could think of is that a lot of the cars I can think of that are 4x4" don't have spigots to centre the wheels, which is a bit of a no-no with wobble bolts.
sparkyt
selling stuff
Jul 25, 2011 18:03:48 GMT
Think your having us on most 4x4's run 6 bolts in a very wide pcs .. never mind the diff locks in the hubs etc . You'd have to be good on a lathe to make up some very mad adapters .. good luck bud
RobinJI
Jul 25, 2011 18:06:19 GMT
Think your having us on most 4x4's run 6 bolts in a very wide pcs .. never mind the diff locks in the hubs etc . You'd have to be good on a lathe to make up some very mad adapters .. good luck bud I'm fairly sure that when he says 4x4 he means 4 bolt by 4" PCD, rather than 4 wheel drive.
Jul 26, 2011 13:17:46 GMT
Or he could mean a Golf Country/Synchro, or BMW 325iX, those are 4x100 4x4s...
4x100 vs 4x4HARDCORE
@hardcore
Club Retro Rides Member 190
Jul 26, 2011 15:27:57 GMT
I got offered a 525iX for literally peanuts a few years ago - I still don't know why on earth I didn't snag it..
Jul 26, 2011 17:32:08 GMT
4" PCD on a Vauxhall Victor or Viva running 100mm will damage the studs and they may break.
4" PCD on a Morris Minor running 100mm wheels WILL break the studs.
Not sure about Minis or Reliants.
Use wobble nuts or better still wheels the correct PCD.
Jul 26, 2011 17:46:46 GMT
Thanks guys, it was for some 4x100 allycats for my viva. Unfortunately I lost out on Ebay anyway.
Many thanks for your swift replies though, most helpful.
4x100 vs 4x4ChasR
@chasr
Club Retro Rides Member 170
With something like Alleycats, I reckon you'll stumble across a set with a 4x4" PCD soon enough .
I was about to tell you there is someone tying to shift a set over on turbominis, but having just reread the thread to make sure they're still available etc, I'm guessing you know about them? Unless someone else brummy based is loking for a set for a viva, and just lost out on another set on ebay....... pretty long odds i reckon!
Current fleet: '58 A35 (half mine) '67 11 window splitscreen vw (half mine) '77 mini 1000 (not quite 1000 any more!!) '86 Armstrong MT500 '89 XR4X4 '94 Corrado VR6 Some sort of sevenesque kit car (no age yet!!) '01 Mondeo estate 2.0 (engine eventually destined for kit car!) - scrapped, engine only left! '98 E300 estate, rusty but seemingly reliable, fast-ish tat hauler. eventual engine donor A35 van, or whats left of it after it lived in a field for many years
Jul 27, 2011 17:22:14 GMT
Ha ha cheers.
Yes, that's me! You'd make a cracking internet detective! Lol.
