suffolkpaul
Retro Free - just a pug 406 with 230k miles on it...
Jul 18, 2006 20:43:06 GMT
evenin'
sorry not been on here much recently but my excuse is a good one..been getting my hands dirty on the 309 track car!!! ;D
however.. i was wirebrushing the front wishbones (lot of surface rust) ready for hammeriting and noticed that the front left spring looked a little "odd".... in that it had broken in three places..rotten all the way trough!
it had just done the 200 mile drive down the motorway only 2 weeks before!
so anyways, got some AVO front spring on order - is it a tricky job to change springs or can it be done by a mechanical novice like me? I understand the physics of most things but not the skill to change much .... hence the track car..
what tools will i need? anything special? a cramp to close them up ? you get the jist..
all help greatfully received..
ta
slater
Club RR Member Number: 78
changing springsslater
@slater
Club Retro Rides Member 78
Jul 18, 2006 20:58:45 GMT
You will need some spring compressors (probably)
Jul 18, 2006 21:01:49 GMT
you'll need a pair of spring clamps and possibly a ball joint splitter. if its on a pug, you might need some strange french spanner/socket sizes, 16, 18, 21mm. should take a couple of hours for a novice with a haynes jokebook, taking account for probs and mistakes
suffolkpaul
Jul 18, 2006 21:32:10 GMT
cheers...
I aim aiming on getting it done in a 3 hour window on sunday afternoon. will invesigate the spring compressors.
Jul 18, 2006 21:55:23 GMT
I took the springs out of my 205 diesel, and to my surprise their free length was about 2.5 times the compressed length!!! Well OK maybe thats an exaggeration but they were very long and it was a real sod to get the spring compressors off and then get the new springs squished down enough to be installed. I tried to work out in my head what the benefit of this might be compared to using shorter (and thus easier to install) but proportionally stiffer (thus giving the same spring rate when installed) springs, but in the end I gave up and drank a cup of tea instead.
I guess it must mean a more constant stiffness over the length of the suspension travel.
Last Edit: Jul 18, 2006 21:56:13 GMT by Mr_Bo11ox
changing springsrustingdeathtrap
@GUEST
Jul 18, 2006 22:16:10 GMT
On a 309 you'll need. 19mm socket for wheel nuts 32 or 36 mm socket for driveshaft nut 16 or 17mm socket for track rod end 13mm socket or spanner for top mount nuts the bottom pinch bolt is a 16mm nut on an 18mm bolt The hardest thing to undo are the drop links, sometimes you can get spanner on them but some types don't allow it so you'll need mole grips or stilsons. You'll need a pair of spring clamps and i think an 18mm offset ring spanner and 8mm allen key to undo the top mount from the shock. I think thats about it, been a while since i worked on a pug though ;D ;D
bstardchild
Club RR Member Number: 71
changing springsbstardchild
@bstardchild
Club Retro Rides Member 71
Jul 18, 2006 23:03:02 GMT
Fark me I thought he had a passat!!!!!!!
If you need spring compressors and don't want to buy any got a set I can loan for a weekend
changing springsarthurbrown
@GUEST
Jul 18, 2006 23:05:49 GMT
I do tend to cheat on this kinda thing......
compressed air on the spring compressors and possibly the longest ball-joint separator known to man makes life SO much easier.
Got it down to 1hr to fo the whole car, including saturday hangover. KWAL.
