Jul 18, 2011 17:40:44 GMT
hi guys, recently bought a gearbox off of here to put in the wifes 405, it is a be3 gearbox which looks the same apart from a few subtle differences... hers is a be3TT box and has what appears to be a ventilated bell housing wheras the other one hasnt.. am I likely to find any other differences???
cheers
Nick
dog296
Jul 18, 2011 18:23:42 GMT
Doubt it.
I've just changed mine in my pug from a XUD lump to a HDi version. The original was vented, this one isn't. There's a big gap under the box for ventlation lol!
only things I'd say swap, would be your sensors, other than that, you'll be cooking!
BTW - it's arrived then?
Jul 18, 2011 19:34:01 GMT
No it should be fine, only thing I can think of is to check the clutch actuation, in case it's a 'pull' rather than the 'push' in the 405 ?
'A' series trigger wheels and sensor brackets, 205 GTi radiator brackets, general fabrication and machining - www.gsmotorsport.net
Jul 18, 2011 21:32:23 GMT
hi mate yeah was there first thing this morning... as to clutch.. ill be using my own clutch stuff on it.. still debating just robbing 5th gear out of ot and fitting it to my box
