vambo
Ratrods, Muscle Cars, Pornography and Death Metal!
Jul 16, 2011 14:19:19 GMT
Hey y'all! have tried igniting it with hair spray and a not so tight fitting inner tube around the edge but still no joy, i wouldnt of thought this was an extream stretch?
anyone have any advice how to get them on?
cheers
1970 Hillman Avenger 1980 Datsun 240K Skyline 1992 Volvo 240 Torslanda 1992 Toyota Hilux Turbo Bizzle 1995 Volvo 850 T5 ![](http://img135.imageshack.us/img135/3447/mybanner4904c33f5bb7ake3.jpg)
Jul 16, 2011 14:29:41 GMT
Use a cheater
Jul 16, 2011 14:31:10 GMT
Failing that, I live in Leeds, I could take it to my tyre bay near harrogate and try and pop it on for you
craig1010cc
Club RR Member Number: 35
Jul 16, 2011 14:32:43 GMT
When me and bruce refitted a 185/60/14 onto the 14x8 bandies, we found that you needed to make sure that the back bead of the tyre was seated and then lots of hairspray into the tyre and it went on a treat. Did need quite a bit of hairspray and a couple of goes to get it right
vambo
Jul 16, 2011 14:45:00 GMT
Failing that, I live in Leeds, I could take it to my tyre bay near harrogate and try and pop it on for you may well be taking you up on this, but gonna give it a go with lots of hairspray again! thanks you thank you thankyou!
vambo
Jul 16, 2011 14:46:11 GMT
When me and bruce refitted a 185/60/14 onto the 14x8 bandies, we found that you needed to make sure that the back bead of the tyre was seated and then lots of hairspray into the tyre and it went on a treat. Did need quite a bit of hairspray and a couple of goes to get it right will give it another go, lots of spary you say?? valve core in or out?
craig1010cc
Jul 16, 2011 14:50:06 GMT
we left the valve in, but had an airline to hand to get air pumping in it as soon as it had popped.
vambo
Jul 16, 2011 14:54:13 GMT
heh heh just had another go and no luck, just goes whoooooffff! and the flame shoots out the sides
they are mk2 golf rims banded out to 8"
Jul 16, 2011 15:19:51 GMT
The way i usualy do it (when i forget a lighter) is put a strap around the outside of the tyre and do it up as tight as i can then pump it up. Ive never done a real big stretch though so not sure how it would work.
bortaf
Jul 16, 2011 17:07:34 GMT
The usuall way is to remove the valve core dump as much air in as possable whilst sitting on the tyre and moving it till you find the sweet spot, at least thats how we used to get standard mini tyres on 6 inch 8 spokes ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) or kneel on the tyre (center of the tread) that spreads the beads out wider.
Last Edit: Jul 16, 2011 17:08:29 GMT by bortaf
R.I.P photobucket
Dez
Club RR Member Number: 34
Jul 16, 2011 17:46:36 GMT
valve core out, wheel upside down, so theres a smaller gap between tyre and rim bed. lots of hairspray, about 30 seconds worth, and make sure its really into the tyre as a cloud, not just sat on the surface. if it don't go with a f-king big bang, youve not got enough hairspray in there. if its just goes 'wuft' you need about twice as much. you need the valve core out cos if you don't itll blow it out with that much of a bang. have the compressor standing by ready to bosh a load of air it or itll suck itself straight back off. i put 165/65r13 on an 8j last week doing it, got em on first go. EDIT- heres an old vid i did of 205/50R15 on a 10J rim- ![](http://img.photobucket.com/albums/v617/dezaster/th_MOV00223.jpg)
vambo
Jul 16, 2011 18:01:37 GMT
Dude! looks like I'm gonna have to try some more, did you have the bead seated on this vid?
Last Edit: Jul 16, 2011 18:42:14 GMT by vambo
Jul 16, 2011 19:05:53 GMT
More fun with hairspray ![](http://vid719.photobucket.com/albums/ww196/Minikid14/th_VID00001-20110325-2117.jpg)
vambo
Jul 16, 2011 19:16:47 GMT
More fun with hairspray ![](http://vid719.photobucket.com/albums/ww196/Minikid14/th_VID00001-20110325-2117.jpg) heh heh what are you actually doing?
Jul 17, 2011 20:59:58 GMT
....or, if you've got some bottles handy..... couple of seconds of gas, five of oxy, put your earmuffs on and light. Then get some air in sharpish before she sucks back off.... ![](http://i620.photobucket.com/albums/tt282/joemortiboy/th_MOV04346.jpg) Joe
