Jul 14, 2011 19:15:05 GMT
I'm after a fuel tank to fit my kit car to increase the capacity from 6 gallons to as big as I can get. The bigest fuel tank size I can get to fit under the floor is 60cm wide x 65cm long x 18 - 20cm deep (fiiler neck needs to be one end) . Any idea what tank will fit in that area or any for sale of about that size ideally with a sender unit please. Something like this Thanks Allan
Allan and Gromit the Growler. Hustler 6 - work in progress
Jul 16, 2011 18:53:29 GMT
Anyone have any ideas on this please
Jul 16, 2011 18:55:58 GMT
bug tank ?
Jul 16, 2011 19:34:41 GMT
My mate has his own company making alloy fuel tanks,proalloy make fuel tanks to order, he can help you out. www.proalloy.co.uk
1961 FORD POPULAR 100e 2.0 dohc Mk1 2dr Ford cortina
Jul 16, 2011 20:52:17 GMT
Thanks guys, any idea of the dimensions of a bug tank?
just measured mine and its 740 x 400, oh well.
Jul 17, 2011 20:57:13 GMT
MGB tank sounds pretty much exactly what your after.
Jul 22, 2011 20:16:22 GMT
Hi Guz, that may be Ok, because the exhaust may be shifted a little, any idea of the depth and how much do they hold?
Wild oliver, do you have the dimensions of the MGB tank please?
Jul 25, 2011 12:30:00 GMT
Anyone know the dimensions of the above 2 tanks
Jul 25, 2011 16:27:03 GMT
dunno depth off top of my head, i can squeeze about £35 in at current prices.
Jul 26, 2011 12:24:17 GMT
Thanks Guz, not much bigger than a mini van tank as fitted as standard.
Need more info on the MG tank
Anyone have one lurking in their shed/garage which might fit the bill. Or does anyone know the dimensions of the MGB tank
how about fitting a second tank? Sounds like it would be far far easier and cheaper
Did think about that, but 2 x mini van tanks would be £200+, so one MGB tank would be cheaper, but need the sizes of one or a similar one
Jan 15, 2012 20:27:49 GMT
Does anyone have a VW Polo tank (cica1985/90) they could measure for me, been told its very similar dimensions to what I'm after. I think it will hold 9 gallons, which would be Ace for my kit car.
Jan 17, 2012 19:46:14 GMT
Anyone ? Please
Dez
Club RR Member Number: 34
Fuel tank and/or info wantedDez
@dez
Club Retro Rides Member 34
Jan 17, 2012 19:56:57 GMT
would it happen to be a pilgrim bulldog kitcar? id guess so looking at that tank
Jan 17, 2012 20:38:59 GMT
polo tank is longer than you want, and capacity is no greater than a bug tank, i can get about the same in. (yes, i run one of them too !)
Jan 18, 2012 19:58:41 GMT
Hi Dez, its a Hustler 6. (6 wheeled mini based beast).
Guz, I can have a bit more length (OOO EERRR) by re-routing the exhaust. Also the polo tank holds 9.2 gallons, so would be ideal
Jan 26, 2012 20:54:37 GMT
Anyone help on the size of a Polo tank? Please
