mickB
ne help,maybe my VW transporter crew cab running Ford 2.8i v6 has a running problem,can anyone help the 2.8i motor isn't behaving as it should when it gets warm - say 15-20 mins driving - the engine revs increase.....and increase....and increase.... until its revving its knackers off,is there any sensors/solenoids/ecu's that control engine RPM against engne temp ? haven't worked on a V6 before only crossflow & pinto carb motors and for the last 15 years VW aircooled motors,so I'm real stuck thanks
help I'm trapped in old car hell..........
Hmm, the idle air control valve could be knackered. Or the warm-up regulator? Or the thermo-time switch.... I can't recall what fuel system the Cologne V6 runs... K-Jet I'm guessing
MWF
Jul 14, 2006 10:36:52 GMT
2.8 V6 runs K-Jetronic MFi and the 2.9 V6 runs full Efi.
Very important to make sure what you have before asking for diagnoses.
Rising revs might Warm Up Reg (WUR) or idle control valve as mentioned.
Jul 14, 2006 12:09:23 GMT
i think you should post some piccies up too Mick.
Jul 14, 2006 12:42:07 GMT
Yeah some pics of your wedge would be great. The WUR / idle air valve are easy to replace. You could test the idle air valve by disconnecting the hose when it's warm and over-revving to see if it dies down after that. The WUR should be easy to test with a multimeter but I'm not too hot on electrics so I won't go any further!
mickB
Jul 14, 2006 12:48:52 GMT
cool cheers all for the advice,its deffo a 2.8 mech injection (bit like the old Golf system) and not the 2.9efi you guys are saying same as the peeps on NSRA message board,so I'm on a winner ;D I reakon cheers again
mickB
Jul 14, 2006 21:08:46 GMT
Jul 14, 2006 21:10:40 GMT
Jul 14, 2006 21:47:49 GMT
same here that is so sweet
Jul 14, 2006 21:51:43 GMT
dude, that's awesome
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
Jul 14, 2006 22:14:56 GMT
got a few warm up regs if you need one
mickB
Jul 14, 2006 22:30:58 GMT
got a few warm up regs if you need one if thats what it is i'll take one deffo n thanks all for the comments
no worries just let me know if ya need it i'm off to garrys pinic in a mo so won't be back till late sunday
Jul 17, 2006 10:29:02 GMT
That's one sweet crew cab!!! My mate has one for sale... this makes me sorely tempted. Great work! Let us know how you get on with the engine problem!
