micrat
Building a Kanjo styled Cinquecento :)
Jul 11, 2011 20:46:16 GMT
Hello peoples!
will be removing the massive electric sunroof assembly from my rover soon as its pointless, and heavy (and at the top of the car too so not the best place for weight in a track-biased build!)
was just wondering the options as far as a blank goes...
rivet a plate? perspex and some windscreen sealant? weld it up?
obviously I know those are all options, any pro's and cons though?
oh and option 4 I thought of tack welding a couple of braces under the apeture, then using the original glass sunroof (detached from the mechanisms etc) and rubber seal plonked down with a bit of sealant, as I know its a perfect, leak free fit...
any advice welcome!
mike.
Last Edit: Jul 11, 2011 20:46:50 GMT by micrat
longman
Club RR Member Number: 3
sunroof blanking advicelongman
@longman
Club Retro Rides Member 3
Jul 11, 2011 21:43:47 GMT
A pal of mine just hoiked it all out of his 911SC track rat , saved16 kilo's .. went perspex
Paul 98 500 SL 86 911 Carrera/sold 23 Octavia Phev
mrwall
Jul 11, 2011 21:45:43 GMT
on some of the Honda sites they are buying carbon ones and boltong/bonding them in.
that ^^^perspex don't look too clever IMHO.
longman
@longman
Jul 11, 2011 21:51:10 GMT
Should have said he has inserted a full roll cage into it as well.... I had the sunroof removed in mine , filled with a hand made panel , it was bonkers expensive , if its just a track rat it doesnt matter what it looks like does it?
Last Edit: Jul 11, 2011 21:53:47 GMT by longman
BiAS
Insert witty comment here
Club RR Member Number: 147
sunroof blanking adviceBiAS
@cheeqi
Club Retro Rides Member 147
Jul 11, 2011 21:59:15 GMT
1mm ally sheet, selection of blind pop rivets, bit of sikaflex, jobs a good 'un
(car+wheels)-rideheight=WIN
Dez
Club RR Member Number: 34
sunroof blanking adviceDez
@dez
Club Retro Rides Member 34
Jul 11, 2011 22:12:13 GMT
or if you want it to look really good, get a bead rolled stepped edge put on it, then rivet it on with the panel fitted from the inside using countersunk rivets so it sits flush
BiAS
@cheeqi
Jul 11, 2011 23:35:16 GMT
^^Yep, that would look really good. I would've done that except my sunroof was an aftermarket one and once removed left an edge on the roof that looked like the hole had been gnawed out by an angry badger with blunt false teeth
Last Edit: Jul 11, 2011 23:35:53 GMT by BiAS
micrat
thanks guys, think riveted ally is the way foward! the car is still my daily at the mo, would be a bit worried someone could just peel off that perspex and get in, imagine its pretty wobbly and noisy too!!! not that its the lap of luxury anymore will be interested to see how muhc weight i can lose!
Jul 15, 2011 21:01:14 GMT
depending on your roof gutter arangements sometimes its easier to weld in a whole roof panel.
Jul 16, 2011 21:44:57 GMT
Be careful with welding. If its close to the edge you can send heat into the windscreen and it cracks. Ask me how I know
sparkyt
selling stuff
Jul 16, 2011 23:16:45 GMT
The best result is to cut a full roof out of a donor car it would be very hard ( lots of filling and flatting ) to get it nice after paint any other way .. leave the last inch and cut the rest out . Weld your new roof in complete . Bit of filling and paint for protection then check the roof ? Or paint
Jul 17, 2011 11:55:44 GMT
id have to agree with the above. Complete roofskin is a lot easier than trying to patch in new metal and fill/ sdand smooth and once done will look a lot neater and retain its strength that can be lost with a sunroof removed and a plate and a few rivets in its place
micrat
Jul 17, 2011 16:01:15 GMT
cheers guys trying to see if they did a rover 200 series without a sunroof, if not, bit of sheet will weld in nicely! looks arent that important to be honest, the car is black so would probably just satin black the entire roof...
Jul 17, 2011 21:44:57 GMT
sunroof blanking adviceHARDCORE
@hardcore
Club Retro Rides Member 190
Jul 18, 2011 12:49:23 GMT
I went for what you've listed as Option 4, but my sunroof was metal to start with and weighed virtually nothing once it was unbolted from the slider mechanism & motor (which weighed a ton!) - I used some simple brackets to bolt it back in using the existing bolt holes. Hard to say how well this would work with a glass one tho - probably best to go for BiAS' technique
VIP
Jul 18, 2011 16:29:31 GMT
depending on your roof gutter arangements sometimes its easier to weld in a whole roof panel. Of course, technically that would result in an IVA.
RobinJI
Jul 18, 2011 17:16:10 GMT
depending on your roof gutter arangements sometimes its easier to weld in a whole roof panel. Of course, technically that would result in an IVA. I don't see why it would. You're allowed to replace panels, and you're allowed to add metal where there was none before, which is all you'd be doing.
