Jul 10, 2011 19:26:03 GMT
I took the head off my 2l inj pinto engine today (205 block) and after cleaning up the piston CROWNs i could see some numbers. What do they mean? Theres a number '3' with an arrow: Them there's some smaller numbers: Any ideas?
Dez
Club RR Member Number: 34
Numbers on pinto pistons?Dez
@dez
Club Retro Rides Member 34
Jul 10, 2011 22:23:54 GMT
the larger number- I'm not sure, but id assume the pistons are numbered if they're matchweighted with the con-rods. theyd usually be scratched in by an engine builder rather than factory stamped though. the arrow usually points towards the flywheel. so you get the piston abcin the same way round after replacing rings.
the smaller numbers are just factory production codes/model numbers afaik. the big M means they're made by mahle.
bortaf
Jul 10, 2011 22:34:58 GMT
Arrow IIRC ? points to the front of the engine and the number is a grade used during the initial build, either weight of the bore grade, no real idea what the others are, on aftermarket pistons they are the size ?
Last Edit: Jul 10, 2011 22:38:42 GMT by bortaf
R.I.P photobucket
Jul 10, 2011 23:19:41 GMT
they look aftermarket IMO
i thought the arrow pointed to the front too
tried googling the small numbers?
RobinJI
Just had a look at a piston next to me, which I know to be made by Mahle aswell (Out of a 1.8 20vt VW engine), it has the same M stamp, also with small numbers above and bellow it in the same format, an arrow pointing towards the front (cam-belt end) of the engine, the diameter and '1' stamped into it, and it happens to be from cylinder 1, I'm fairly sure that's no coincidence.
Last Edit: Jul 11, 2011 2:03:51 GMT by RobinJI
bortaf
Jul 11, 2011 13:02:16 GMT
Just had a look at a piston next to me, which I know to be made by Mahle aswell (Out of a 1.8 20vt VW engine), it has the same M stamp, also with small numbers above and bellow it in the same format, an arrow pointing towards the front (cam-belt end) of the engine, the diameter and '1' stamped into it, and it happens to be from cylinder 1, I'm fairly sure that's no coincidence. It is on a pinto, my EFi has 3 3's and a 2, we're talking about shoddy ford build quality here not metromomic VW efficiency when cosworth "selected" the EFi blocks for the early cosworth 16v turbo they selected blocks where all the numbers on the pistons were 2 or 3 which is in the middle of the casting tolerence, 1s and 4s were left for us normal peeps to use.
R.I.P photobucket
RobinJI
Jul 11, 2011 13:58:50 GMT
Ah, yeah, it could well be a coincidence. The only thing that makes me think it isn't is that I've gone over it with black marker, and I remember marking each cylinder assembly as I dismantled the engine. If it had been a random un-related marking I'd have expected my self to write the 1 somewhere else, rather than going over the factory stamp. It was a year or so ago though. Plus like you say, they're different manufacturers.
Last Edit: Jul 11, 2011 13:59:30 GMT by RobinJI
Jul 11, 2011 15:23:56 GMT
I've got some Mahle pistons (Dolly Sprint) with the same M stamping on the top too, with the arrow, but the grading system on them is a letter (F on these)
bortaf
Jul 11, 2011 21:05:00 GMT
Ah, yeah, it could well be a coincidence. The only thing that makes me think it isn't is that I've gone over it with black marker, and I remember marking each cylinder assembly as I dismantled the engine. If it had been a random un-related marking I'd have expected my self to write the 1 somewhere else, rather than going over the factory stamp. It was a year or so ago though. Plus like you say, they're different manufacturers. It could well meen that on a VW i was serious when i said shoddy ford Vs way better VW build quality ;D even though the build quality on the later blocks was better than the early they are still shoddy in comparison to some other manufacturers
R.I.P photobucket
Jul 13, 2011 16:56:42 GMT
mine are all number 3's so that's a good sign then!!
