Jul 13, 2006 16:03:35 GMT
German car electrics are normally pretty good in my experience, but for some reason the offside indicators are flashing too quickly - its behaving as if a bulb has blown but all 3 bulbs are actually working and flashing.
Any ideas? This is all that is stopping my W201 from being road legal!
Cheers!
Jul 13, 2006 16:12:04 GMT
Relay?
Jul 13, 2006 17:59:59 GMT
I had the exact same problem with my BMW. Strangely, it cured itself after about a week. Wierd.
Jul 13, 2006 18:15:33 GMT
wrong size bulb? a 5w bulb where a 21w bulb should be will cause the same problem
Merc indicator flashingBenzBoy
@benzboy
Club Retro Rides Member 7
Jul 13, 2006 22:05:45 GMT
Hmm, my car had the same problem. And that used to cure itself too! Bad earth somewhere?
mercmad
Jul 13, 2006 22:56:50 GMT
W201?,it's a bad earth,remove all the flasher bulbs on that side and clean them,I would also replace the flasher unit .try hazard flashers,if they are acting strangely you need a new unit.The flashers are supposed to flash once every second( from memory) if they flash faster the unit must be replaced.
Rob
You know, for kids!
Jul 13, 2006 23:09:23 GMT
sounds like a bad earth 'tricking' the relay into thinking there's a bulb out - the flashers are load resistant and quite sensitive but the bulb doesnt need that much to flash so a dirty contact would cause it... same as everyone else's answer that wannit !?
