Jul 12, 2006 11:41:07 GMT
I quick fancy some 15" steels either 6j or 7j wide to fit my Volvo 480. As it has a renault drive train it use renault/vw stud pattern of 4x100 pcd and a rough offset of 35et. Can anyone recommend a supplyer or source of such wheels?
I understand banding wheels is illegal for road use?
Jul 12, 2006 11:43:01 GMT
Yes very illegal!
Note if you wish to go 7inch wide consider that a different offset say around 30et may be required due to inner rim fowling suspension parts (remember if wheel goes wider offset may sometimes need to alter)
Last Edit: Jul 12, 2006 11:48:59 GMT by TwincamGTi
Jul 12, 2006 11:44:13 GMT
Ok just thought i would confirm my suspicions
Jul 12, 2006 11:47:07 GMT
Re-rimming isn't, but it's hard to find someone to do it - and even harder to find someone to do it well.
Jul 12, 2006 11:58:07 GMT
I quick fancy some 15" steels either 6j or 7j wide to fit my Volvo 480. As it has a renault drive train it use renault/vw stud pattern of 4x100 pcd and a rough offset of 35et. Can anyone recommend a supplyer or source of such wheels? I understand banding wheels is illegal for road use? I would look at something like megane steelies, or Citroen berlingo van, as they will be 6x15 anyway I think even latest Clios are on that size
Jul 12, 2006 12:29:07 GMT
there was a guy on ebay flogging vauxhall delivery wheels for curse word all they were 15x6
Jul 12, 2006 13:07:34 GMT
BMW Mini Steels are 6"x15" - not sure on offset though (hairnet600 would know, and has a set for sale )
Jul 12, 2006 13:27:16 GMT
I got looking for Corrola ones on ebay, plus check out FS section for those wellers.
Jul 12, 2006 13:28:55 GMT
VW golf G60 steels - 7x15, still get them brand new from VW for £30 each.
Jul 12, 2006 13:45:20 GMT
thats cheap! what offset are those seventynine?
Jul 12, 2006 15:07:01 GMT
ET40
Jul 12, 2006 15:07:03 GMT
VW golf G60 steels - 7x15, still get them brand new from VW for £30 each. Bloody hell thats cheap! do you know the part no. or will my local vw dealer parts dept know what i want if i ask for G60 steels!
Stu
Jul 12, 2006 15:09:37 GMT
VW golf G60 steels - 7x15, still get them brand new from VW for £30 each. Bloody hell thats cheap! do you know the part no. or will my local vw dealer parts dept know what i want if i ask for G60 steels! Are you sure they are 7J width, I thought they were 6J? The are officially Passat wheels if I remember correctly when asking the dealer. That said, my dealer seemed to quote some odd prices when I asked about some a few years back so I didn't bother, would quite like a set though.
Last Edit: Jul 12, 2006 15:10:28 GMT by Stu
Jul 12, 2006 15:19:14 GMT
These are 4x100 PCD, have an ET38 and come under Passat part no: Steel Wheel: 357 601 025M £29.62 + VAT each Spare (Space saver): 535 601 025A £37.15 + VAT each Centre Caps: 871 601 171 £4.03 + VAT each Wheel Bolt Caps: 321 601 173A Around £0.40p Each Blatantly stolen from ClubGTi
Last Edit: Jul 12, 2006 15:19:53 GMT by prophet
dp
DP Race Tech
Jul 12, 2006 15:37:10 GMT
seventy nine in da house: VW golf G60 steels - 7x15, still get them brand new from VW for £30 each.They are 6" wide not 7", same rims as Passat G60 and Seat Ibiza TDI I payed 40€ each from Seat for those I have on Skoda Shop Hack.... DP says: I guess if you want wider they have to be banded.....
Last Edit: Jul 12, 2006 15:38:41 GMT by dp
Jul 12, 2006 15:47:08 GMT
cool thanks again for the help guy!
Jul 12, 2006 16:27:02 GMT
......plus check out FS section for those Wellers. That'll be these Wellers then! 4 x 100 PCD. Offset is APPROX 20mm. 15" x 7. Wheels in Bristol. Steve 07971 661221
