Hi, I'm after a cheap motor with the XU 1.9 turbo diesel engine in, preferably the version with the Bosch mech fuel pump and T2 turbo.
They can be found in Peugeot 306 & 406, and others like Citroen Xantia. I do NOT want the HDi or the 2.1TD, it has to be the XU 1.9 ;D
Ideally it needs to have a few months MOT on it so I can run it over the summer before I pull the engine out for a conversion. I'm located in the northwest so the closer the better really! And obviosuly the cheaper the better. Cosmetic condition absolutely NOT important, as long as the engine is kosher, I'm interested.
thanks!
thanks!
