I know it isnt really that old and not really that retro, but i figured theres sure to be someone on here that can help!
The wifes tig has been running fine, then on sunday I decided to move it off the drive, so i could do some work on my car. Drove the tig maybe 12 feet, then parked it up. Came back to it later in the day to go and pick the mrs up and the damn thing wont start.
the engine turns over, but refuses to fire up, any common causes?
I noticed that i couldnt hear the fuel pump priming, but not sure if i could hear it when the car was working, so maybe its nothing.
So far I have tried:
1. tried a spare coil pack - no change
2. checked fuses in fuse box - all good
3. tried spare key - no change
4. took drivers door handle apart, as it was broken anyway. (the hand-book metions that the tigra has some form of mechanical immob. built into the locks) found part of the metal mechanism has snapped. there is a small micro-switch which i believe controls the deadlock function. from what I can tell, the broken bit is meant to make contact with said microswitch.
5.checked all visible connections and condition of ignition parts (all the obvious stuff
6. made sure it actually has petrol in it!
I'm thinking that the car is suffering from either a dead fuel pump/fuel pump relay (anyone know where the relay is?) or some other wierd electrical gremlin
can anyone tell me where the fuel pump relay is hidden? i couldnt find it anywhere!
any help would be much appreciated. got my mechanic mate coming to look at it tomorrow.
oh its a 1.4 16v of around 98 vintage
have a couple of pics of the useless tig
